Turbo Lag at high boost
Old Oct 1, 2006 | 07:47 PM
boostedf22cd5's Avatar
Default Turbo Lag at high boost
Hi fellow HT, I have a 94 accord with an F22B1 with a T3/T04e turbo running at 8 psi's. Well last saturday I decided to run it at the races and i misshifted so it redlined like crazy. The next run I ran, the turbo was lagging when boost was engaged so i popped the hood and found out that the hose running from the external wastegate to the intake piping next to the intake manifold had popped off. I connected the hose back and it was still lagging. I decrease the boost to 4 psi's and it's running fine but anything above 4 psi, it will lag. Also my A/F ratio is jumping from lean to stoich constantly. It never did that before. Could my A/F ratio use some tuning? What can i do? Please help. Thanks
Old Oct 1, 2006 | 07:49 PM
shauniewalnuts's Avatar
Default Re: Turbo Lag at high boost (boostedf22cd5)
vac leak? idle surge?
Old Oct 1, 2006 | 07:55 PM
Default Re: Turbo Lag at high boost (shauniewalnuts)
well my vac is reading a little below 20 if that helps. It idles fine but I do notice that the car is running a little rich because of the constant lean to stoich even at idle it does that
Old Oct 1, 2006 | 08:08 PM
i would re check all of you vac lines to holes or whatever, also how bad did you misshift, was the clutch let all the way out? there is a possibility of bent valves from the high rpm of the misshift causing piston to valve contact from valve float... this could cause lack of vacuum. i know my car usually at idle has between 20-25hg
Old Oct 1, 2006 | 08:30 PM
if it is what you said it possibly could be, then wouldn't my car run like **** even with the boost at 4 because even at 4 it's running perfect. Just not as fast and exciting as it was at 8
Old Oct 1, 2006 | 08:33 PM
yea i guess it would run like **** all the time, what fuel management are you runnin? hondata? crome? fmu?
Old Oct 1, 2006 | 09:31 PM
omg i'm such a dumbass....i'm new to FI so i switched the spark plugs without gapping them....I just put the old plugs back on and i'm good to go again...thanks for the info and help though
karmadhi
Oct 1, 2011 04:12 PM
black_ek
Jun 24, 2008 11:30 PM
project civic
Mar 31, 2005 09:38 AM
slwazgsr
Jun 23, 2003 03:45 AM
