turbo kit question
Old Feb 15, 2006 | 10:43 AM
typeRobtypeS's Avatar
Default turbo kit question
i was thinkin about removin my turbo kit off my gsr and returning it to stock then sellin it to a friend. the kit would include: t3/t4 turbo, turbo manifold, wastegate, intercooler, ic piping, charge piping, bov, downpipe, dumptube, injectors and/or fmu, vafcII, boost gauge, 3inch turbo exhaust, air filter, oil lines, missing link. my question is after removing all those parts what else would i have to do to return it to stock other than exhaust manifold, exhaust, intake, stock injectors. the car was just tuned with the injectors and the vafc. would the 255 fuel pump have to be changed out? is there anything else im forgetting? if i end up sellin it to my friend i might be able to get alot of the stock parts from his gsr. can u guys help me out here, i appreciate it. thanks
Rob
EDIT: yeah i forgot the oil pan
Modified by typeRobtypeS at 12:03 PM 2/15/2006
Old Feb 15, 2006 | 11:00 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: turbo kit question (typeRobtypeS)
youd need to plug the return line in the pan, remove the feed line to the engine and reinstall the oil switch, those are 2 more things that come to mind.
Old Feb 15, 2006 | 12:08 PM
Default Re: turbo kit question (boostedcivicsir)
so what about the fuel pump? and what else...
Old Feb 15, 2006 | 06:30 PM
anyone?
Old Feb 16, 2006 | 08:58 AM
JDM turbo DC's Avatar
476 whp / 323 tq @ 17 PSI
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir &raquo;</TD></TR><TR><TD CLASS="quote">youd need to plug the return line in the pan, remove the feed line to the engine and reinstall the oil switch</TD></TR></TABLE>
...and dont forget to plug up the vacuum lines where the bov and wastegate was tapped or you'll have a huge vacuum leak.
Old Feb 16, 2006 | 10:06 AM
Default Re: turbo kit question (JDM turbo DC)
yeah. and what about the injector resistors? when i had it tuned they put new resistors in. would i be fine leaving them in or what?
Old Feb 17, 2006 | 11:11 AM
anyone else have any ideas??? i know someone else has some input on this
Old Feb 17, 2006 | 03:32 PM
bump
Old Feb 17, 2006 | 08:39 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by typeRobtypeS &raquo;</TD></TR><TR><TD CLASS="quote">yeah. and what about the injector resistors? when i had it tuned they put new resistors in. would i be fine leaving them in or what?</TD></TR></TABLE>
if you take out the injectors since they are low impedence and ur going to put stock injectors (high impedence) in, then yes, remove the resistor box
Old Feb 17, 2006 | 09:29 PM
spoon95eg's Avatar
B A N N E D
From: Orange County / Palm Springs 714/76hoe, ca, usa
Here's the list hope this help and end this
Block the oilpan with something
Return the oil sensor in the back of the block the vacuums
take of the missing link
reset the vafc 2
Timing (move the distributor in the middle)
Stock spark plug if u have the one step colder
Fuel pump is ok for na or boost
Not but not the least if u have a chipped ecu take it off and get a stock ecu
Done
Old Feb 18, 2006 | 06:02 AM
Default Re: turbo kit question (spoon95eg)
thanks guys i appreciate it. if i end up doin this and have any other questions ill know where to ask.
vtecace23
Sep 19, 2011 12:48 PM
1tgalon
Dec 16, 2010 10:45 PM
gsrswap
Aug 1, 2008 05:15 PM
OEMJDM
Jan 21, 2003 03:37 PM
