turbo itr
Old Aug 18, 2004 | 12:03 AM
Liquid R6's Avatar
Default turbo itr
just wanted to see what u guys think of turboing a usdm itr
Old Aug 18, 2004 | 12:27 AM
Ceres's Avatar
it can be done? why do you ask? People do have turboed ITRs..
What is your question about it?
Old Aug 18, 2004 | 12:37 AM
mEr's Avatar
mEr
Default Re: turbo itr (Liquid R6)
that is a very general question, what are your plans..be more specific for informed answers
Old Aug 18, 2004 | 01:07 AM
donkiman's Avatar
i think iv seen it before???
Old Aug 18, 2004 | 02:41 AM
FOrSfEd's Avatar
Default Re: turbo itr (donkiman)
I'm not to sure if that can be done with such high compression.
Old Aug 18, 2004 | 02:57 AM
MiraiZ's Avatar
Default Re: turbo itr (FOrSfEd)
search function is your friend!
Old Aug 18, 2004 | 03:12 AM
Misfit's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FOrSfEd &raquo;</TD></TR><TR><TD CLASS="quote">I'm not to sure if that can be done with such high compression.</TD></TR></TABLE>especially not one with JDM ITR pistons and 11.1 CR
Old Aug 18, 2004 | 03:28 AM
swlabhot's Avatar
Turbo in an ITR Is it even possible?!
Old Aug 18, 2004 | 03:36 AM
JDM_Risa's Avatar
Default Re: turbo itr (swlabhot)
come mon guys do a search.........itr206 on honda-tech was very sucessful....made like 295whp at like 6psi or something.....
high compression to compenstate low boost
spoolin time is really good since its not so boost dependant
low compression lots of boost lots of lag simple as that
there are plenty of turbo'd R's its been done.....
Old Aug 18, 2004 | 03:37 AM
HybridKOOP's Avatar
Don't turbo an ITR...
Haven't you heard that LS motors are better for boost because VT3K doesn't matter in FI?
Be sure to use an LS transmission also, because everyone knows that longer gears are better for boost as well.
Old Aug 18, 2004 | 06:07 AM
patdemps's Avatar
Default Re: turbo itr (HybridKOOP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridKOOP &raquo;</TD></TR><TR><TD CLASS="quote">Don't turbo an ITR...
Be sure to use an LS transmission also, because everyone knows that longer gears are better for boost as well.</TD></TR></TABLE>
haha
Alright, ill try to shine some light. Yes, you can turbo an ITR. My opinion is to search and learn a shitload more about it before you even think about it. Because if you don't even know if you can turbo your car then you've probably got a good amount of learning ahead of you. But this isn't a bad place to start. Look up some threads in the archives and recent topics and just take in as much as you can.
It can very easily be done. However, with the high compression your definately looking at a very minimal room for error, better make sure you have a good tuner in your area and you need to spend money and get some very good engine management (Hondata, Uberdata or AEM). Tuning will be 100% the key to your setup. Piecing it together will be very easy, as there is quite a bit of options. It all depends on your power goals and if you want to build up your block or stay stock.
Old Aug 18, 2004 | 06:12 AM
m R g S r's Avatar
I think you could have some fun with a turbo R.
Old Aug 18, 2004 | 06:41 AM
BoostedsiR's Avatar
Are you ******* kidding me have you ever tried that, sorry didnt mean to flame you but that is untrue
Old Aug 18, 2004 | 06:55 AM
HybridKOOP's Avatar
Default Re: turbo itr (BoostedsiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedsiR &raquo;</TD></TR><TR><TD CLASS="quote">
Are you ******* kidding me have you ever tried that, sorry didnt mean to flame you but that is untrue </TD></TR></TABLE>
If you took me seriously, then you must not know me. I am a sarcastic ********.
Old Aug 18, 2004 | 06:56 AM
PM-Performance's Avatar
you cant turbo type R's unless you put a Spoon Vtec fluid and JDM wrist pins in your pistons. then it will hold like 30-32 psi fine.
Old Aug 18, 2004 | 07:11 AM
FOrSfEd's Avatar
Default Re: turbo itr (itr206)
Thanks for the insight Pete I will be purchasing those items right now
Old Aug 18, 2004 | 07:12 AM
any time man , glad i could give some insight.
Old Aug 18, 2004 | 07:23 AM
DC2R714's Avatar
Dont forget JDM Mugen Coolant. Then you wont overheat.
Old Aug 18, 2004 | 07:24 AM
Default Re: turbo itr (DC2R714)
HAHAHAHAAH thats classic, that guy never PM;ed me back after i suggested that. lol
Old Aug 18, 2004 | 07:25 AM
B18C1CYA's Avatar
but dont you need the spoon radiator hoses to go with the coolant?
Old Aug 18, 2004 | 07:40 AM
FOrSfEd's Avatar
Default Re: turbo itr (B18C1CYA)
I think you have to use everything together or stuff will no work properly.
Old Aug 18, 2004 | 07:43 AM
B18C1CYA's Avatar
you know what i think your right
Old Aug 18, 2004 | 08:43 AM
kbizasss's Avatar
Dont forget the APC radiator cap extension, lowers the temps for everything in a 3inch radius of the cap...such as hood, valve cover, all that hot ****.
Old Aug 18, 2004 | 08:47 AM
Liquid R6's Avatar
welll the thing is ima get my engine/tranny swap done sometime soon... and i was wondering what would be fast... i dont wanna go all out like omg its the fastest car in the world... just something fast enough for me and be able to have fun with... i eventually plan to go turbo and run about 6-7 psi at the most and i just wanted peoples opinions on a turbo r.... cuz after all the itr was perfected by honda to me intened for all motor, and if i put a turbo on it it defeats the whole purpose of gettin a itr and i might as well get a gsr with ls tranny... also another option i had in mind was a 97+ h22 which i also plan to eventually turbo but i dont kno how much engine space ill have to play with wit the h22 in an ek... also i dont think there is much aftermarket for an h22 compared to a b18
Old Aug 18, 2004 | 08:52 AM
Liquid R6's Avatar
seriously.... do i REALLY need to get jdm vtec fluid... wrist pins... mugen coolant and a spoon radiator hose? i dont wanna believe it but u guys make it seem like ur so serious about it
