Turbo Install!! Need Help!!
Old Apr 19, 2004 | 10:56 PM
rollydc69's Avatar
Default Turbo Install!! Need Help!!
The set-up: Full-Race Stage 4 Turbo kit (T4/T67)
Question 1: How I'm gonna put the nut on the head if I don't have any clearance on this manifold???
same thing on cylinder #1.
Question 2: If I'm gonna line up the compressor side of the turbo to the back door intercooler, the IC core is not gonna be on the middle anymore. Is this okay??
V-band
Thanks in advance guys.
Full-Race Javier Thank you very much for all your help!!
Old Apr 20, 2004 | 12:53 AM
lilxvtecxpwr's Avatar
Default Re: Turbo Install!! Need Help!! (rollydc69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rollydc69 &raquo;</TD></TR><TR><TD CLASS="quote">Question 1: How I'm gonna put the nut on the head if I don't have any clearance on this manifold??? </TD></TR></TABLE>
take the nuts off all the other studs and pull the manifold out forward until you can fit the nut over the hole on the head flange. then spin the nut onto the stud while holding the manifold up. just put the two nuts you're having trouble with on first, then the others after that.
EDIT: oh yea, nice car/setup. i wish the t3's came v-band...would make life so much easier.
Old Apr 20, 2004 | 12:59 AM
wowsers's Avatar
Default Re: Turbo Install!! Need Help!! (lilxvtecxpwr)
1. ^ good answer
2. it's ok. might look weird through your bumper though.
Old Apr 20, 2004 | 03:05 AM
99blackcivicSi's Avatar
Question 1: How I'm gonna put the nut on the head if I don't have any clearance on this manifold??? pull out and put those 2 on first same with any mani that has probs like this
Question 2: If I'm gonna line up the compressor side of the turbo to the back door intercooler, the IC core is not gonna be on the middle anymore. Is this okay? yes it is ok that is how it is designed </TD></TR></TABLE>
Old Apr 20, 2004 | 05:13 AM
rollydc69's Avatar
OK. Thanks.
JAYDmManny1331
Jul 14, 2009 09:59 PM
93baggedcivic
Jul 27, 2007 07:04 PM
ekb16a
59
Jun 21, 2007 10:02 PM
erck
Sep 13, 2006 04:16 PM
RyanAutry
May 2, 2003 12:22 PM
