TURBO INFO
Old Nov 20, 2006 | 11:11 AM
175Shot4Door's Avatar
Default TURBO INFO
how much HP do u think this is good for ????
TURBO
BRAND NEW IN THE BOX
3" INLET DIAMETER
2" OUTLET
WET FLOATING BEARINGS
1/8 NPT OIL INLET
T3 / T4 FOOTPRINT OK !!
SPECS:
.50 A/R / .63 HOT SIDE
STAGE III WHEEL
TURBONETICS CAST HOUSING
BALANCED AND BLUEPRINTED AND COMPRESSION TESTED
Old Nov 20, 2006 | 11:13 AM
stealthmode62's Avatar
Default Re: TURBO INFO (175Shot4Door)
I'd go with anywhere from -10 to 876 horsepowerz. Depends on your gear sprocket bracket ratio.
Old Nov 20, 2006 | 11:25 AM
Schister66's Avatar
Man U FTW
by the sound of the description, its an SSAutoCrap turbo...which is good for about 566.7 horsepowerz....a little lower than previously thought
Old Nov 20, 2006 | 12:24 PM
hopefully its good for atlest 355
Old Nov 20, 2006 | 12:34 PM
Schister66's Avatar
Man U FTW
what kind of turbo is it?? It sounds like SSAC and if that's the case, you're not going to be making any power for any length of time because they are piles of **** imported from China....the sad part is, people buy them because they "look" good
Old Nov 20, 2006 | 12:46 PM
Hondacivicnut's Avatar
Default Re: (Schister66)
Agreed! Check out this link I just found.This is where they'll be coming from....
http://mgpracing.en.alibaba.com/
Tjabo
Sep 19, 2006 07:13 AM
rusteds2k
May 11, 2005 03:02 PM
trooper0641
Oct 12, 2004 10:12 PM
RyanAutry
Jan 5, 2003 10:43 AM
