Turbo help on GSR
Old Sep 28, 2002 | 06:40 PM
B18CivicEJ's Avatar
Default Turbo help on GSR
I have a 98 GSR. I plan on getting the Greddy Turbo Kit within the next couple months. But first I would like to make my engine ready for it with some better internals. I would just like to get some opinions on different ways to approach this.
I was thinking of getting JE Pistons with a compression ratio of 9.5:1 and replacing the head gasket with a Cometic. Any other suggestions or should I try a different route. I plan on running 7-10 psi when installed with some other mods. Trying to do it all one shot.
Old Sep 28, 2002 | 06:50 PM
APEX i GSR's Avatar
Default Re: Turbo help on GSR (EvoTeg325)
here you need these
https://honda-tech.com/zerothread?id=292500
Old Sep 28, 2002 | 08:12 PM
FredoSP's Avatar
As far as fuel mgt. what are you planning to use, the GReddy "Blue Box" or a standalone like Hondata?
Old Oct 2, 2002 | 04:50 PM
B18CivicEJ's Avatar
Default Re: Turbo help on GSR (FredoSP)
I plan on using a stage 3b Hondata.
Old Oct 2, 2002 | 05:24 PM
gsr sol's Avatar
I have done that setup already and I can tell you it will move. I have a Drag kit on mine and I went with JE 9:1 pistons. I think 9.5:1 would have worked better for more power out of boost so stick with it. I've got the Hondata 3b as well. Good luck...
OneBadDC2
Apr 14, 2008 10:43 AM
Joeballz85
Jun 16, 2005 11:06 PM
Aeka GSR
Dec 9, 2003 06:01 PM
DC2NR
Jul 14, 2003 11:09 AM
bew
Jun 14, 2003 06:28 PM
