turbo help ???
Old Jan 13, 2006 | 03:51 PM
kcjohnnyboy's Avatar
Default turbo help ???
i have a 93 civic hatch with a b1 and im in the process of going turbo, but i had a couple questions about torque specs and the bolts and studs. i want to know what the torque specs for all the bolts if anyone can help. and for the bolts and studs, i heard for the manifold people use heat treated bolts instead of studs with nuts. i was doin some research and i read that people that used the studs with nuts that the studs broke after some time. but i dunno, which is more reliable? but if you guys can help that would be great. thanks for the help
Old Jan 13, 2006 | 04:23 PM
platinum00's Avatar
Default Re: turbo help ??? (kcjohnnyboy)
Your best bet is to go get a bentley manual. They are well worth the money
platinum.
Old Jan 14, 2006 | 12:28 PM
i have the drag manifold so should i use the stock head studs for the header
oodie
Aug 20, 2009 10:54 PM
90Integra_Rs
Jan 12, 2007 08:39 PM
CivicK20
Nov 11, 2006 06:03 PM
FredoSP
Jan 19, 2004 07:09 PM
koy
Feb 9, 2002 05:16 PM
