turbo getting to much oil
Old Jul 28, 2003 | 04:34 AM
2DXtreme's Avatar
New User
Default turbo getting to much oil
i have a 99 civic dx hatch with a dsm t25. My oil feed line is an -4an. I am getting to much oil to my turbo and it's burning it like crazy can anyone tell me what i should do. I read something about a valve just befor the oil inlet but it wasn't very detailed. Any kind of help would be great.
Thanks
Old Jul 28, 2003 | 05:01 AM
shotty's Avatar
Default Re: turbo getting to much oil (2DXtreme)
You should be using a -3an feed line. That helps to restrict the flow.
Old Jul 28, 2003 | 02:17 PM
BROOD's Avatar
What are you using for a crankcase vent/breather? (stock or aftermarket)
Modified by SLPR at 3:33 PM 7/28/2003
Old Jul 28, 2003 | 02:20 PM
2DXtreme's Avatar
New User
Default Re: turbo getting to much oil (SLPR)
im using the stock
Old Jul 28, 2003 | 02:31 PM
g2ls_turbo's Avatar
last time i got cheap, i just used a homedepot water line for the day, its steel braided like 6an or some ****, it had no leaks or problems. maybe your seals are bad? you can also use a restrictor but i dont know where you can find them. just make things easy and use a 3an.
Old Jul 28, 2003 | 02:34 PM
BROOD's Avatar
Default Re: (g2ls_turbo)
I would check your crankcase pressure, if it is high you may want to look into an addition to your oil separator system. (ENDYN, SSR, Greddy all make oil separator cans) and use ENDYN's installation instructions.
High crankcase pressures restrict oil return lines and cause oil build up in the turbo center housing....thus passing oil through the seals.
If you are still passing oil from the turbo seals, I would also suggest changing to 3AN feed line, it can't hurt. Good luck
What are you using for the return line?
Old Jul 28, 2003 | 03:55 PM
2DXtreme's Avatar
New User
Default Re: (SLPR)
i'm using a 1/2 inch radiator hose
Old Jul 28, 2003 | 04:58 PM
Jockobo's Avatar
Default Re: (2DXtreme)
im using a -4 an for the oil feed on my t-25 and no problems here.
tuhboek
Jun 21, 2010 05:51 AM
sampol999
Sep 3, 2006 01:09 PM
Prelude91siT
Jan 19, 2004 06:24 AM
revhigh96
Sep 6, 2003 08:19 PM
ziggity
Jan 10, 2003 11:56 AM
