turbo gauges
Old Sep 22, 2006 | 12:19 PM
BUBBLE BOY's Avatar
Default turbo gauges
what would be the 4 most important gauges assosiated with boosting your car to have and why
and if some one would have a list of all the gauges assosiated with boosting your car can you please post
Old Sep 22, 2006 | 12:29 PM
joppe's Avatar
Default Re: turbo gauges (BUBBLE BOY)
1. Wideband afr gauge
2. Boost gauge
3. Egt gauge
I have them. Next would be oil pressure & temp.
Old Sep 22, 2006 | 12:32 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: turbo gauges (joppe)
1 wide band - you need it end of story
2 boost - again you need it end of story
those are the only 2 i own,
3 oil pressure, i don tbecause i would be constantly staring at it
4 egt because it can show changes in timming that a wideband cant pick up.
Old Sep 22, 2006 | 02:12 PM
Jason703Racing's Avatar
Default Re: turbo gauges (boostedcivicsir)
1 Boost gauge
2 Oil Pressure gauge
3 MAYBE a wideband gauge to verify airfuel
4 pointless
Old Sep 22, 2006 | 02:21 PM
SovXietday's Avatar
Default Re: turbo gauges (Black00em1)
Wideband - obvious reason
Boost - obvious reason
Oil Press - absolutely!
Water Temp - Having a more accurate reading as to where the temperature of your coolant is a must IMO. If my car reaches anything over 225 I will immediately pull it over and let it cool before continuing on, after which I will flip my fan switch to have it on permanently.
Old Sep 22, 2006 | 02:45 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: turbo gauges (SovXietday)
i have the following
Wideband o2
Individual cylinder egt as well as post turbo (egt is pointless if you only have one)
oil pressure
water temp
fuel pressure
boost pressure
Old Sep 22, 2006 | 02:51 PM
EJ1 wilcox's Avatar
Default Re: turbo gauges (wantboost)
Seems like everyone is pretty much on the same page as to what gauges are important.
For me, I'm too cheap to have a wideband in my car full time (low buck setup anyways).
So, my gauge setup is as follows:
- Oil pressure
- Boost
- EGT
I think EGTs are important in a boosted car for situations where you are in boost for a long period of time, you want to know if and when your EGTs shoot up so you can let off the gas before you melt a piston. I drive up a lot of hills where I am in boost a lot, so EGT can be a lifesaver.
Old Sep 22, 2006 | 03:59 PM
BB6-213's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black00em1 &raquo;</TD></TR><TR><TD CLASS="quote">1 Boost gauge
4 pointless</TD></TR></TABLE>
I think a wideband is far and away the most important gauge you can have.
Old Sep 23, 2006 | 07:42 AM
Mr. Badwrench
Default Re: turbo gauges (BB6-213)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BB6-213 &raquo;</TD></TR><TR><TD CLASS="quote">I think a wideband is far and away the most important gauge you can have.</TD></TR></TABLE>
next to boost yes.
if you can only afford 2, those are the 2 you need.
i think i will actualy be putting in a fuel pressure gauge.
Old Sep 23, 2006 | 09:18 AM
pgmatt's Avatar
Boost,water temp and oil pressure.
Old Sep 23, 2006 | 09:46 AM
HiProfile's Avatar
Default Re: turbo gauges (pgmatt)
Oil pressure - any loss can kill your motor. Most important IMO.
Water temp - overheat a motor and you're in deep ****.
Boost - you actually don't need it, since you should have overboost protection already, and a set boost level. Your motor can overboost faster than your eyes can pick it up & react.
Wideband - not really needed unless you got a questionable tune a few years ago.
Thats for running a tuned car. For tuning a car: the WB gauge is good, but your datalogging *will* work better than your eyeballs. An egt is great if you do timing, although that needs some skill interpretting it.
suprachica79
Jul 13, 2007 05:49 PM
cibola
13
Jun 23, 2005 11:43 AM
B16Civic93
Jun 8, 2005 07:21 AM
igo4bmx
Jan 28, 2005 02:58 PM
