turbo exhaust question??
Old Jul 27, 2010 | 04:58 PM
96electronH's Avatar
Default turbo exhaust question??
im going to turbo my ls in the beginning of next year but plan on replacing my shitty exhaust i have now before then, my question is what would be a good priced not ridiculously loud exhaust i could get now that would not be very restrictive when i boost it.
i plan on having around 250hp with a 3" dp and a full 3" exhaust to match it.
i found this kteller its a 3" but it has a resonator not sure if it will be restrictive or if this one even sounds good
http://www.kteller.com/shop/index.ph...mart&Itemid=71
Old Jul 27, 2010 | 05:08 PM
EsotericImage's Avatar
Retired Moderator
Default Re: turbo exhaust question??
I would goto VRS exhaust and get the tubing kit. Vibrant makes resonators and mufflers that are pretty quiet and non restrictive.
If you need a cat look alike for visuals, Votionspeed.com has them cheap.
all together your looking at 400ish
450 for adding the resonator on that site (add 75), but still is a decent deal all put together.. I might look into this when i go 3"
Old Jul 27, 2010 | 05:21 PM
ok ill def check that out do u guys think that kteller exhaust would be restrictive?
Old Jul 27, 2010 | 05:22 PM
Retired Moderator
looks pretty straight to me..
Old Jul 27, 2010 | 05:26 PM
have u had a magnaflow or heard it?
Old Jul 27, 2010 | 05:57 PM
Retired Moderator
im using a magnaflow resonator at the moment.. works great1!
looks like their muffler on the end also.. its a decent set up for 450.
Old Jul 27, 2010 | 06:47 PM
boostedeg302's Avatar
kteller exhausts are awesome. I built my exhaust myself with tubing from summitracing.com and a magnaflow muffler from them as well. Sounds great and was fairly cheap. I probably had around 250 in the whole setup including making the downpipe
Old Jul 28, 2010 | 08:02 AM
KTeller8's Avatar
Here is a comparison between a skunk2 and KTeller Exhaust; KTeller full system. If you dont like the magnaflow muffler, you can get the system without it, we call that a bolt up system/kit. Any questions, please let me know. We have a few video clips on the website under the KTeller Tv section.
94_CRVtec
May 26, 2005 06:54 AM
blackccoupe
Jun 1, 2004 10:12 PM
prelittlelude
Jul 30, 2003 12:10 PM
bluedelsol
Sep 10, 2002 07:57 AM
