turbo b16 injectors
Old Apr 6, 2009 | 04:06 PM
Dev15Bizz's Avatar
Default turbo b16 injectors
like it says b16 turbo w/hondata s300... getting bigger injectors
what is the difference in low impedance and high impedance?
the lows say it has 2 ohms of resistance and highs are 12 ohms.
which ones do i need and why?? i know the size i need and i think i need low impedance but can someone explain the difference please??
Old Apr 7, 2009 | 05:52 PM
Dev15Bizz's Avatar
Default Re: turbo b16 injectors
nobody
Old Apr 7, 2009 | 05:57 PM
boostedcivicsir's Avatar
Mr. Badwrench
first off what power level are you looking for?
if you are using hondata, you will be best suited with saturated injectors 12-13 ohm injectors (i get the impedence messed up all the time i am making the assumption that high = saturated)
Old Apr 7, 2009 | 06:38 PM
tony1's Avatar
High impedance are what you want.
Old Apr 9, 2009 | 02:57 PM
Dev15Bizz's Avatar
not a whole lot, 8-10 psi
Old Apr 9, 2009 | 03:22 PM
Mr. Badwrench
boost has something to do with it but again,
what POWER LEVEL are you looking for? power made is directly related to the fuel you can burn. and 8-10 psi means nothing because we dont know what turbo you are using.
loveda07
Mar 2, 2009 08:03 AM
B18 rider
Aug 8, 2008 10:51 AM
99_red_si
Mar 1, 2008 09:14 PM
turbodelslo
Jul 4, 2006 09:59 AM
XX Boosted Si XX
Mar 16, 2004 06:52 PM
