Turbo b16 good setup?
Old Oct 4, 2004 | 09:08 PM
Maverik4k's Avatar
Default Turbo b16 good setup?
Blox Manifold
presicion sc50
rc 440 injectors
Uberdata (local shop tune)
Downpipe/piping/hardware/oil (local shop)
johny race car Intercooler
hks bov
255 walbro Fuel pump
tail wastegate
sparko boost gauge (it works...)
What do you think about this setup? what about the turbo choice?
will a b&m fpr be efficient for this setup?
also what size wastegate should i get? im going to get a 7psi spring
Also im trying to keep my ac, you think it will fit with that big of a turbo?
going on 93 civic coupe w/b16a2
hoping for exleast 220whp
Already have:
Aebs intake manifold
Hondata gasket
bored 65mm tb
greddy evo2 exhaust
Modified by Maverik4k at 6:20 AM 10/5/2004
Old Oct 5, 2004 | 06:19 AM
Maverik4k's Avatar
Default Re: Turbo b16 good setup? (Maverik4k)
bump. any help?
Old Oct 5, 2004 | 12:13 PM
Maverik4k's Avatar
bump again
Old Oct 5, 2004 | 12:19 PM
donkiman's Avatar
you have to let us know the specs on the turbo that determines if its a good turbo for your setup and goals. the stock fpr will be fine for your setup. other than that all sounds good. you should hit 220whp easily.
Old Oct 5, 2004 | 12:24 PM
Maverik4k's Avatar
Default Re: Turbo b16 good setup? (donkiman)
Precision SC50 50 Trim 450 Hp
Old Oct 5, 2004 | 12:28 PM
m R g S r's Avatar
GT32E, equal length manifold, b16a, @ 7.5psi made 265whp.
Old Oct 5, 2004 | 12:35 PM
-Trinitron-'s Avatar
220 is not an unreasonable goal with that setup...
Old Oct 5, 2004 | 12:46 PM
rmcdaniels's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Maverik4k &raquo;</TD></TR><TR><TD CLASS="quote">Precision SC50 50 Trim 450 Hp</TD></TR></TABLE>
No need for anything that big. Personally I'd look for a turbo that makes about 300 HP and will spool up faster, like a T3 or a small T3/T4. I mean if you are getting a SC50 for free then bolt it up and go, but bigger turbos are laggy, especially with a low torque engine like a B16. You should be able to get a downpipe to clear the A/C if you keep it down to 2.5".
I'd also get rid of that tail wastegate and get a tial, I hear the tail wastegates don't hold much pressure and tend to be noisy when they open up, I know mine is.
skyliner186
Northeast (Sales)
Dec 4, 2006 02:11 PM
skyliner186
Nov 30, 2006 03:38 PM
95si
Feb 2, 2003 04:23 AM
skellator_thoj
Jan 22, 2003 02:48 PM
MugenNSX
Oct 4, 2002 03:50 AM
