Turbo air filter
Old Feb 5, 2012 | 05:20 AM
jim mcfeely's Avatar
Icon2 Turbo air filter
Wondering what people are running for a filter on there street turbo cars, turbo is a 58/57 thanks
Old Feb 5, 2012 | 05:40 AM
Turbo-LS's Avatar
Default Re: Turbo air filter
I have been running autozone ricer filters on my car for years. They filter great and are cheap to replace
Old Feb 5, 2012 | 06:55 AM
Whiterice-gsr's Avatar
run any high flow filter that fits, just stay away from the sponge ones they blow apart and get sucked into your motor. mine just happened to fit perfectly, i got rid of the power steering cooler though.
Old Feb 5, 2012 | 09:52 AM
Turbo-LS's Avatar
never though of ditching the PS cooler. I gotta find a way to get my car to run cooler now that im in Texas. might have to do something different with the a/c
Old Feb 5, 2012 | 10:18 AM
it gets pretty hot up here in the summer i had no issues with it my power steering works fine and all i did was cut out the cooling loop. also on track days and autocross days no issue whatsoever, i never researched it it was in my way and pissing me off so it had to go lol, honestly if i lost power steering i wouldnt fix it i would just delete it. if u run a good dual core aluminum rad u should have no problem with heat, u can try water wetter too that stuff actually works. used to run it in a camaro i had with overheating issues. also a bigger pan and oil cooler can really help.
Old Feb 5, 2012 | 10:29 AM
IN VTEC's Avatar
I used an AEM Dry Flow filter on the turbo first. There's a variety of sizes you can choose from.
With a backdoor intercooler, you can make use of the fender for cold air plumbing.
Old Feb 5, 2012 | 10:40 AM
SiRCiviC94's Avatar
these are the filters were avoiding? I also have a K&n with a flat rubber top
Old Feb 5, 2012 | 10:56 AM
yes these are the ones to avaoid, the only ones worth a damn were the original hks ones but there are so many fakes now that u should avoid them all together, go with aem or k&n or whatever brand u like really that fits in there.
Old Feb 5, 2012 | 10:58 AM
thats not a bad idea at all, in the second picture u have there is the exact reason i moved the power steering cooler but i looped it up closer to the pump
Old Feb 5, 2012 | 11:01 AM
Turbo-LS's Avatar
yeah foam filters are crap
i like my cheap autozone unit
Old Feb 5, 2012 | 11:08 AM
thats a nice clean setup.
Old Feb 5, 2012 | 11:14 AM
SiRCiviC94's Avatar
lol damn... atleast I didnt pay for it off the shelf or anything.
Old Feb 5, 2012 | 11:43 AM
racebum's Avatar
hmm, you guys with the driver side air inlet have a tighter fit than i will. with passenger side air inlet mounting you can run a short 3" tube to the filter have have it sit in the open space behind the overflow water bottle
Old Feb 5, 2012 | 12:14 PM
SiRCiviC94's Avatar
better? room to spare!
Old Feb 5, 2012 | 12:22 PM
crvtectim's Avatar
Turbo-LS, I run the same style, but in black. Get them at Advance for around $20 bucks, iirc. Fits the 4" inlet perfect and barely squeezes between turbo and frame.
Old Feb 5, 2012 | 12:30 PM
im not diggin where the wastegate is placed and where the dump tube goes, looks kinda sloppy and just thrown together. i really like that top mount i may have to try a top mount out with my next turbo.
Old Feb 5, 2012 | 12:48 PM
Thanks for all the feedback
Old Feb 5, 2012 | 02:20 PM
LightningTeg's Avatar
Community Builder
Go to K&N and pick one from the hundreds of sizes and shapes
Old Feb 5, 2012 | 03:02 PM
SiRCiviC94's Avatar
dump is being switched to just a straight down drop tube under the car... that one used to recirc to the exhaust
I could place it direct and not use the 90 elbow but this should work for the wastegate itself
Old Feb 5, 2012 | 03:06 PM
thats where mine goes just right down to the ground.
Old Feb 5, 2012 | 06:18 PM
Turbo-LS's Avatar
Thanks Whiterice, thats actually before i cleaned it up. I dont have that crappy msd coil anymore, and i cleaned up the wiring and everythign quite a bit. Last thing i need to do i get a real catch can and weld some bungs on the VC instead of those threded ones.
Old Feb 5, 2012 | 08:13 PM
SiRCiviC94's Avatar
why not just use the stock set up and put an air filter on the valve cover vent? its worth it to run a can for 2 lines extra venting?
Old Feb 6, 2012 | 05:52 AM
Turbo-LS's Avatar
Because when your making alot of power you have to run more piston to wall gaps there for you end up with more crankcase pressure and the black box and tiny port on the valve cover doesnt cut it for proper ventilation of the crankcase.
My engine has quite a bit of crankcase pressure. at idle the air pushes out of that nipple on the valve cover pretty hard and my catch can has smoke coming out of it from fuel/oil vapors. Im running .0040 PTW and .0022 ring gaps so i need all the ventilation I can get.
Old Feb 6, 2012 | 12:56 PM
ya im not there yet i removed the pcv and vent the valve cover via tube to the ground. proper can is on my list not just not at the top lol.
Old Feb 6, 2012 | 01:35 PM
speaking of coils im really diggin the cop conversion from a k series. heres a pic of my engine bay as u can see i still have alot of cleaning to do lol. what turbo are runnin under there.
