turbo accord problem
Old May 11, 2002 | 07:56 PM
NXAccordTO4B's Avatar
Default turbo accord problem
Hey guys, i just guy my car running. Having some problems need some input. First of all this is what i got:
f22b1 (fully built) (rods, pistols. etc..)
fmax turbo t3/t4to4b
NX direct port (100shot)
full MSD
Hypertech fuel pump
RC 370cc
and all ur basic stuff
*note stock ECU*
*note honda accord 97*
anyways this is my problem. I can't get my car to rev pass 4200rpm! Yes, i check for vacuum leaks, timing is good. Car pulls great up the point of 4200 rpms then i bogs down and won't gooooo any wheres. thanks for your input.
[Modified by NXAccordTO4B, 4:57 AM 5/12/2002]
Old May 11, 2002 | 09:45 PM
inspyral's Avatar
Default Re: turbo accord problem (NXAccordTO4B)
I take it you're running some sort of limited MAP? Are you throwing any codes? Sounds like your ECU might be in limp mode, possibly from seeing boost.
Old May 11, 2002 | 10:15 PM
MiraiZ's Avatar
are you using the MF2? if so..lose it!...thats your problem!!
Old May 11, 2002 | 11:25 PM
rjardy's Avatar
pistols huh? what you got 45. cal or 9mm hee hee
Old May 12, 2002 | 12:20 AM
inspyral's Avatar
Default Re: turbo accord problem (rjardy)
Old May 12, 2002 | 06:54 AM
PrecisionH23a's Avatar
what kind of noises are you hearing? Make sure you have enough tranny fluid.
Old May 12, 2002 | 06:54 PM
Default Re: turbo accord problem (GudeH23a)
my mf2 is not connected. Im just trying to get the car to run right before i boost or spray. tranny fluid is good, but note i am getting a tranny engine code, but im not sure if that might be my problem, since the car runs fine before 4200 rpm
Old May 12, 2002 | 08:40 PM
so i assume you checked out and you were running enough tranny fluid?
Old May 16, 2002 | 07:36 PM
yes
sharktlp
Mar 31, 2003 05:18 PM
NXAccordTO4B
Sep 3, 2002 01:08 PM
NXAccordTO4B
May 14, 2002 04:01 PM
