Turbio guys, need help with a TT
Old Aug 27, 2010 | 12:26 PM
StayKrafty's Avatar
Default Turbio guys, need help with a TT
Recently got a HKS TT and no manual or anything for it. Ive found online a diagram of the wires.
Black=ground
blue=acc
red=battery
green=ignition1
yellow=ignition2
grey=ebrake
is this all true?
Now, for the installing it part, which wires should I be splicing? A picture or something would be great. I've got a, 88 crx if that helps. The TT is an older one so im not sure of the model
only picture I could find of it.
Old Aug 27, 2010 | 02:44 PM
StayKrafty's Avatar
Default Re: Turbio guys, need help with a TT
Also, is there a way to test if the TT works first before I start hacking in to my ignition harness?
Old Aug 27, 2010 | 03:47 PM
EF-Devotion's Avatar
to test it just hook it up to your car battery. the red to postive and black to negative. On the wiring you should try posting it on the force induction thread and see if that helps.
Old Aug 27, 2010 | 07:26 PM
mattliston's Avatar
88 crx? HF, STD, SI, BASE
a ton of wiring differences between these models
Old Aug 28, 2010 | 10:08 AM
StayKrafty's Avatar
88 Si. And if thats a way to test them, then my HKS one is no good. I bought a Greddy TT last night and found a ton more help online with that one. 12volt.com shows me which wires are which. So I think I got it now. If I have any more issues, ill post back.
Is hooking up the ebrake part of the timer a must? I know for safety reasons it should be hooked up but thats not what I want to know.
Old Aug 28, 2010 | 04:14 PM
mattliston's Avatar
it simply checks that the ebrake is pulled
how else will the car stay in one spot if its running?
Old Aug 29, 2010 | 05:41 PM
dpetro1's Avatar
link to HKS instructions
http://www.hksusa.com/content/pdf1634.pdf
see part 2 where it talks about the ebrake being mandatory
day1
Feb 13, 2010 04:16 PM
Barcode
Apr 7, 2008 05:25 PM
na96gsr
Mar 20, 2006 02:30 PM
jarel
Nov 3, 2004 09:38 AM
XxAzNsTyLexX
Audio / Security / Video
Sep 25, 2002 06:12 AM
