tunning Q
well i just swap my ls turbo from my 93 civic to my 94 integra ls. it is tune with s200 when it was in the civc and everything from the civic went into my integra except the walbro255 fuel pump.. so my question is do i need to tune it again or is it jus fine the way it is. it still has the dsm injectors and everyting else.thanks guys.
If you cant retune it yourself, it would be way cheaper to buy a $90 fuel pump than take it to a shop. I switched from an inline pump to an in tank pump and I had to modify my fuel maps, and it wasn't linear either.
Steve
Steve
well if i get the same fuel pump that i had in my civic than i dont need to tune it right? since it was allready tuned before in my civic and all i will be doing is putting it in my integra with all the same set up. correct me if i am wrong thanks.
yeah u have to retune because when u swap it to a different car, you are using different muffler bearings. no im jk, u dont have to retune if its the exact same setup and just transferred to another car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18 CYA »</TD></TR><TR><TD CLASS="quote">yeah u have to retune because when u swap it to a different car, you are using different muffler bearings. no im jk, u dont have to retune if its the exact same setup and just transferred to another car.</TD></TR></TABLE>
lol what about i exact same set up BUT the differnet fuel pump? because i dont have the walbro anymore and i am going to have to use the stock ls fuel pump.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm2teg »</TD></TR><TR><TD CLASS="quote">well if i get the same fuel pump that i had in my civic than i dont need to tune it right? since it was allready tuned before in my civic and all i will be doing is putting it in my integra with all the same set up. correct me if i am wrong thanks. </TD></TR></TABLE>
If you can get the same fuel pump, it should be close enough you dont need a retune.
