tuning issues
Old Dec 15, 2007 | 06:02 PM
yellowtyper77's Avatar
Default tuning issues
What exactly would connecting a hose directly from the valve cover to the pcv box under the manifold, on a on a boosted b18c1, do?
Old Dec 15, 2007 | 07:34 PM
97grnrs's Avatar
Default Re: tuning issues (yellowtyper77)
dont do that.. they both are vents and if u connect them together the vapors will be stuck inside the motor. connect them both to a catch can with a vent on top and u will be fine. or at minimum just put breather filters on each one. but dont loop them together to each other
Old Dec 15, 2007 | 10:57 PM
Default Re: tuning issues (97grnrs)
what would be the result or symptom if somebody did that? Any
ideas welcome!
Old Dec 16, 2007 | 06:18 PM
boostedblkef's Avatar
hmmmm i wonder
Old Dec 21, 2007 | 11:45 AM
I took it to a tuner and that is what they did. It made the motor smoke and then they said it must have an internal crack. Diagnosis by tuner, "bad motor, needs new one" The pressure simply built up and pushed oil into cylinders through valves. It had a high idle and I guess that is why hose were being moved around?!?!?
Old Dec 21, 2007 | 03:00 PM
96 GSR-T's Avatar
who's teh tuner?
Old Dec 21, 2007 | 03:05 PM
roachsboosted16's Avatar
thats not vacuum thats air breather valve, and it needs fresh air and preferrably a filter, ther on ebay for cheap.
Old Dec 21, 2007 | 03:17 PM
SteamedRice's Avatar
Default Re: tuning issues (roachsboosted16)
the result would be a hose flying off from being pressurized by the crankcase, and not letting the motor evacuate all that ish
Old Dec 27, 2007 | 07:25 AM
Old Dec 27, 2007 | 07:30 AM
96 GSR-T's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96 GSR-T &raquo;</TD></TR><TR><TD CLASS="quote">who's teh tuner?</TD></TR></TABLE>
Old Dec 27, 2007 | 07:37 AM
jmm96gsr's Avatar
You should just PM DaveF - he'll help you out.
Old Dec 27, 2007 | 08:04 AM
philli dyno works. I went down there twice with a tow and the first time they said timing was off. The second time they said the motor was blown because of how they sealed crank case by moving the breather hose to the wrong spot. The hose didnt blow off the pressure was releaving throught the valve seals pushing oil with it causing it to smoke. I called and told them about it and they replied with, "We were not comfortable tuning it". It was a small air leak in the Idle air valve causing a high idle. Timing was corrected and set with the program Neptune even though we fixed it. No timing changes correctly routed hoses and I have 300 HP. NICE, Thanks for nothing PDW !!!
Austin_DC2
Jun 17, 2019 12:40 PM
zeroek
Apr 3, 2011 04:07 PM
DuhQbnSiLo
Jun 26, 2009 08:34 PM
coolusername
Jul 14, 2007 01:45 PM
killah3084
Nov 13, 2005 02:42 PM
