TRYING TO MAKE 275whp..?
Old Apr 30, 2007 | 10:16 AM
burks's Avatar
Default TRYING TO MAKE 275whp..?
I have a stock ls integra with a 2.5bar map sensor 450cc injejctors and a shitty xspower t3t4..how much boost do you guys think i'll need to acheive 250-280whp..i was gonna run 11..can i run more..? consider this is going to be my daily driver and i don't have any more money to put into it so i need to keep it safe..
Old Apr 30, 2007 | 10:54 AM
slodel's Avatar
Default Re: TRYING TO MAKE 275whp..? (burks)
ditch the turbo
3 inch exhaust
maybe a little bigger injectors, always room for improvment
what manifold are you using?
Old Apr 30, 2007 | 11:03 AM
PrecisionH23a's Avatar
The last stock LS I did ran a t3/t04e 60 trim and made 250whp at 9psi.
Don't expect to make a good bit of power and having it last using that xspower garbage.
Old Apr 30, 2007 | 11:13 AM
ragethemachine86's Avatar
your setup should be fine for now, however EXPECT the turbo to fail. my suggestion would be to send the turbo to be rebuilt with garrett internals (blaastperformance.com for example) before you install the kit or tune it. turn around times are fairly quick from what i've heard and costs around 250$.
Old Apr 30, 2007 | 01:00 PM
Default Re: TRYING TO MAKE 275whp..? (ragethemachine86)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ragethemachine86 &raquo;</TD></TR><TR><TD CLASS="quote"> my suggestion would be to send the turbo to be rebuilt with garrett internals (blaastperformance.com for example) before you install the kit or tune it. turn around times are fairly quick from what i've heard and costs around 250$.</TD></TR></TABLE>
Or sell the piece of garbage back on ebay and buy a true garrett unit for $500-600 bucks
Old Apr 30, 2007 | 04:14 PM
m R g S r's Avatar
Default Re: TRYING TO MAKE 275whp..? (slodel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slodel &raquo;</TD></TR><TR><TD CLASS="quote">ditch the turbo
3 inch exhaust
for 275whp 450's are more than enough.....
just turn up the boost until you hit 275whp....with a good corresponding tune of course. . .
scia220
Feb 11, 2011 10:19 PM
VtecKiDD
Mar 12, 2008 04:37 PM
red civic standard
Oct 17, 2007 01:08 PM
AZ90DATEG
Feb 27, 2007 04:18 AM
TURBODC4TEG
Sep 22, 2004 12:45 AM
