is this true... i need some expert advice.
Old Oct 8, 2003 | 03:23 PM
kell211's Avatar
Default is this true... i need some expert advice.
the problem: my car is giving me a cel 3 whenever i get in high rpm's (between 5000 and 5500). so i lowered the boost to 6psi, still threw it. it goes away when i reset the ecu and doesn't come back on until i'm really getting on it. if it were a bad map sensor wouldn't the cel come on all the time and/or not go off when i reset the ecu? i've never had a bad map, what does it do? the only recent things i've done to the car is to insall a iat sensor in the intake pipe, i have no idea if this could be effecting the map?
i called a local mechanic and he told me that i would get a map cel if i was making any boost at all if i wasn't running a check valve or a missing link. this doesn't seem to make sence since i'm not getting the code at low rpm's, even if it's under boost. plus, i've read on here that a stock map sensor should be good for somewhere between 10-11psi. is that only with a check valve?
i'm wondering it this is connected to the boost, the new iat sensor, wastegate, or maybe something to do with the vtec (it kicks in at 5400). any help or direction any one can give me would be really appreciated, cause i have no educated ideas for what is causeing this. and if there is any info i can give to help please ask?
Old Oct 8, 2003 | 06:51 PM
kell211's Avatar
Default Re: is this true... i need some expert advice. (kell211)
bump
Old Oct 8, 2003 | 06:52 PM
espanol's Avatar
what is your set-up?
Old Oct 8, 2003 | 07:00 PM
kell211's Avatar
Default Re: is this true... i need some expert advice. (espanol)
ls/vtec with a .57 a/r t3/t04e. emanage and the profec e-01 to interface with it. what else do you want to know?
silverbulletgsr
May 20, 2004 08:24 AM
kell211
Oct 7, 2003 05:39 PM
Burke
Jul 29, 2003 01:48 PM
HybridCoupe
Jul 1, 2002 11:11 AM
HybridCoupe
Jul 1, 2002 09:55 AM
