True or False
Figure this is the best place to ask this even though its a 1jz lol.
High compression Street Turbo motors Dont last as long as stock compression? (8.5:1)
Debate I had earlier when I mentioned wanting to do a 10 something to 1 C/r all e85 setup.
Consensus was the motor just wouldn't last as long particularly in the bottom end like rings and bearings. just because of the additional stress Higher compression adds to the parts. BS or some truth?
First off I'm not a fan of E85 personal choice and I'm not a tech it's just been proven over years and years high compression and forced induction just doesn't work together. Your not the first one who wants to do this believe me but let me ask you a question its a pretty simple theory that I'm sure everyone on this board has thought about doing it...however no one has...there's a reason for that it doesn't work
https://honda-tech.com/forums/forced-induction-16/high-compression-boost-1389843/
Also search works to
https://honda-tech.com/forums/showthread.php?t=1389843
a good friend that races in EFI Renegade Street has always told me like this in terms of that.
with variables (more boost, higher comp, nitrous) your safe tuning window gets very small.
while it may work, you have little room for error.
and i am trying to remember people saying that the e85 from service stations is very inconsistent.
not saying it wont work, how long still remains the question.
2JZ NA engines use 10:1 CR. A local here has been runing his setup with E85 on 12 lbs. He is a 6sp converted setup and makes over 350 whp. Engine has well over 100k miles on it.
Still using a dizzy but has been runing AEM EMS (yuck) on it. The next buildup he is planning to go with GTE pistons in a 2JZ-GE VVT-i with BC 264 vvt-i cams. The head gasket will be the stock 2JZ-GE to net 9.5:1. The switch over to wastefire ignition from the dizzy should help with a better controlled spark. He plans to push about 20 lbs. on that setup.
There are too many factors to consider about the buildup. I know that there have been guys running over 10:1 with lots of boost on the salt flats. I wouldn't have it on a street driven vehicle.
The bottom end of the JZ engines can take a lot and laugh at you in the process. The bearings are the largest compared to almost any engine out there. Rings don't wear out as easily as Honda rings so you won't see yourself have any issues with excessive blowby.
98civicEX
Jul 31, 2002 07:16 PM
