Trouble with dsm injecters
Old Nov 15, 2006 | 07:51 PM
Mostecstreethb's Avatar
Default Trouble with dsm injecters
I have a ls turbo EF with web turbo cams, Thicker head gasket, MSD fuel pump and chiped ecu and i recently bought some DSM blue top 450cc injecters the car dosent want to idel and it hasatets to rev up is it just to much fuel do i need to turn down the fuel pressure(right now its stock) or does it just sound like the injecters bad another ebay buy. Please let me know im trying to make it to IDRC this weekend and I need the help. Thanx guys
Old Nov 15, 2006 | 08:05 PM
Default Re: Trouble with dsm injecters (Mostecstreethb)
Ohh I heared that the blue top are low imp and that meaans i need to take out the resister box because the resister bix is high imp is this true. Again please help me
Old Nov 15, 2006 | 08:09 PM
playahwitgame's Avatar
you would need to put in a resistor box
Old Nov 15, 2006 | 09:53 PM
ek99's Avatar
Default Re: Trouble with dsm injecters (playahwitgame)
If its a EF, your fine. You already have the resistor box so your good. Your problem is that your chip is not tuned for those injectors. Also, if one of your injectors were bad, your car would misfire and sound like it was running on 3 cylinders.
Old Nov 15, 2006 | 10:50 PM
94hatchvx's Avatar
Default Re: Trouble with dsm injecters (ek99)
take the injectors and get the ultrasonically cleaned and tested. it shouldnt be that expensive. next time make sure you buy a pair that have already been tested and cleaned. just my .02.
Old Nov 16, 2006 | 02:03 AM
blackeg's Avatar
Default Re: Trouble with dsm injecters (94hatchvx)
sounds like you just need some tuning
Old Nov 16, 2006 | 06:47 AM
redzcstandardhatch's Avatar
something different
Default Re: Trouble with dsm injecters (blackeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackeg &raquo;</TD></TR><TR><TD CLASS="quote">sounds like you just need some tuning</TD></TR></TABLE>
yeah, you cannot put injectors in that are almost double the factory size and expect them to do anything.
Old Nov 16, 2006 | 11:37 AM
Default Re: Trouble with dsm injecters (redzcstandardhatch)
Thanx for the help guys thats what i figured and like i said before it is in a EF with a resister box Im gonna try turnning down the fuel pressure and see what happens
Charlie Moua
Oct 7, 2010 07:36 PM
blindsk8er1013
Sep 4, 2009 08:41 AM
b16a27
Sep 19, 2007 04:35 PM
golangti
Mar 15, 2005 09:48 AM
Neukin
Jul 27, 2003 10:51 AM
