Tranny to Engine Bracket - Bolt Size
The Brackets you remove to take the oil pan off that connect the tranny to the engine I lost the two big bolts that screw into the tranny anyone know what size they are.... Also how many bolt are on the intake support on a GSR I cant seem to find those either...
You can look all that up on
http://www.acuraautomotiveparts.org
They usually give the proper bolt size in the description if you don't want to buy from them.
#39 - 12x35
#40 - 12x50
So are all the threads fine threads? Im assuming 60 and 35 is the length correct?
[Modified by BVM, 10:04 PM 3/13/2003]
Yes, you're right. If it's 12x50 then it's a 12mm bolt, 50mm length. I never paid attention to whether they are coarse or fine, I just go to the hardware store and buy the same size as what it says on there. It's impossible to find Grade 8 metrics locally, but most of that crap doesn't need to be Grade 8 anyway.
