tool roll call! name the tools needed for a turbo install
Old Jul 15, 2002 | 09:15 PM
lucas569's Avatar
Default tool roll call! name the tools needed for a turbo install
name all the little things you needed for a turbo install!
this will be great for all those doing their own install for the 1st time
Old Jul 15, 2002 | 09:17 PM
falcongsr's Avatar
What is this crap?
Default Re: tool roll call! name the tools needed for a turbo install (lucas569)
BFH
Mr. Softee's Avatar
socket wrench. sockets
wrenches
sodering gun
vice grips
wd40
socket extension
I think thats all I used.
Old Jul 15, 2002 | 09:18 PM
BoostinDC2's Avatar
drill, hand tools, bubble gum, duck tape and some wood glue
Old Jul 15, 2002 | 09:20 PM
lucas569's Avatar
Default Re: tool roll call! name the tools needed for a turbo install (BoostinDC2)
lots of swear words!
lucas569<---- who couldn't undo the cat bolts and slammed a wrench on the ground, wrench bounces up hits side of door leaving small dent!
Old Jul 15, 2002 | 09:27 PM
BoostinDC2's Avatar
yeah that too..
Old Jul 15, 2002 | 09:33 PM
Etylorcen's Avatar
Band aid's for your busted knuckles hehe.
Old Jul 15, 2002 | 09:38 PM
ThePunk's Avatar
Default Re: tool roll call! name the tools needed for a turbo install (Etylorcen)
Die grinder/dremel with lots-o-cutoff wheels.
Hacksaw.
Old Jul 15, 2002 | 09:50 PM
Flamenco-T's Avatar
Default Re: tool roll call! name the tools needed for a turbo install (ThePunk)
-dremel with cutting bits
-3/8" titanium drill bits to cut your block for turbo clearance and drill IC mounting holes on your bumper support
-8mm, 10mm, 12mm, 13mm, 14mm, 17mm wrenches
-10mm, 12mm, 13mm, 14mm, 17mm socket with 6" extension ratchet
-6.5mm hex key for the tial WG bolts
-flat and phillips screwdrivers
-jack, jackstands
-scissors to cut fuel lines for inline pump
-vice grip
-sharp blade to splice wires for fuel pump and black electrical tape
-Snap ring pliers for HKS SS bov
-lotsa beers, radio and cuss words..
hehehe, damn, I can't believe I memorize them all......;P
Old Jul 15, 2002 | 09:57 PM
Trigun's Avatar
Default Re: tool roll call! name the tools needed for a turbo install (Flamenco-NA)
everything that was mentioned i used except for snap ring pliers ... i spent a small fortune on tools
Eckz2k
Jul 17, 2003 04:41 PM
dirtySOHC's
Mar 26, 2003 11:11 PM
turbocoupe
Oct 22, 2001 09:47 PM
GruvyTune
Oct 20, 2001 05:16 PM
