Too rich at idle!!!!
Old Aug 29, 2003 | 02:13 PM
freddy_hung's Avatar
Default Too rich at idle!!!!
i have a 97 Civic HB.. i have installed a turbo kit with mitsubishi eclipse 440cc/min injectors walbro fuel pump.. i have a apexi S-AFC in order to lean the mixture and compensate for idle ... still i have an over rich condition just off idle .. the car smokes crude gasoline trough the tailpipe.... what can i do to solve the problem???
Old Aug 29, 2003 | 02:16 PM
R6Elmo's Avatar
Default Re: Too rich at idle!!!! (freddy_hung)
how lean are you running the AFC at idle? Are you going to the 1000rpm mark and leaning it out?
There is the posibility the stock fuel pressure regulator doesnt' flow well enough to relieve the excess fuel pressure from teh fuel pump. yet for some reasn, i don't believe the fuel pump realy provides increased pressure at idle
Danny
Old Aug 29, 2003 | 02:21 PM
Default Re: Too rich at idle!!!! (R6Elmo)
well im running at minus 50% .. the maximum allowable... i have the low throttle setting on 0% trh.. so is there..... and still the crude gas pass trough the exhaust
Old Aug 29, 2003 | 02:38 PM
prostreetonline's Avatar
if you are -50% and it's still super rich, something is wrong. Check your base fuel pressure, and check for any vacuum leaks.
boostedblue23
Sep 29, 2017 06:18 PM
dublaaciv
Nov 1, 2005 07:08 PM
quick108
Aug 18, 2001 09:20 AM
