TIMING question on a turbo B16A HELP ME
Old Sep 19, 2004 | 12:35 PM
88crxb16a's Avatar
Default TIMING question on a turbo B16A HELP ME
oK i GOT A TURBO B16. we put a thicker head gasket on the car to lower the compression. The car will start up but won't stay running. We can't get the timing right. Could the distributor cause this. If its not the distributor what else could cause this?
Old Sep 19, 2004 | 02:09 PM
88crxb16a's Avatar
Default Re: TIMING question on a turbo B16A HELP ME (88crxb16a)
!!!!!ANYONE!!!!! i need to car to be running in a couple days
Old Sep 19, 2004 | 07:41 PM
88crxb16a's Avatar
Old Sep 20, 2004 | 06:13 AM
White Smoke's Avatar
i my honda
Global Mod
How much thicker of a HG? You may need a biger timeing belt
Call the Co. that makes the HG and ask them
DO you have any CEL's on?
Runing a check valve?
Waldorf I see I am right near you
Old Sep 20, 2004 | 06:16 AM
88crxb16a's Avatar
Default Re: TIMING question on a turbo B16A HELP ME (si2die4)
2mm hg from inline pro. They said they do that setup all the time and they couldn't even get the timming right. Wouldn't they know if it needed a bigger timming belt.
Old Sep 20, 2004 | 07:28 AM
88crxb16a's Avatar
bump
Old Sep 20, 2004 | 05:53 PM
88crxb16a's Avatar
bump!!
Old Sep 20, 2004 | 05:56 PM
JDogg's Avatar
do you have adjustible cam gears? you will have to compensate with cam gears, or the cam timing will be off.
Old Sep 20, 2004 | 05:59 PM
88crxb16a's Avatar
Default Re: TIMING question on a turbo B16A HELP ME (JDogg)
yea of course i put adjustable cam gears on
Old Sep 20, 2004 | 06:00 PM
impound's Avatar
i've got the 3mm on a b16 and my timing belt worked.....put cam timing to -2 deg i believe....
Old Sep 22, 2004 | 08:28 AM
88crxb16a's Avatar
Default Re: TIMING question on a turbo B16A HELP ME (impound)
Could this be the cause of the distributor even though my ecu isn't throwing any codes? We have tried just about everything but that.
Old Sep 25, 2004 | 09:56 AM
88crxb16a's Avatar
bump
Old Sep 25, 2004 | 03:21 PM
grndcont's Avatar
ya, back when i did that trick i needed camgears, and i think i had to adjust them like 3 or 4' (can't rember which direction though) and your distributor runs off the intake cam so you need to check base timing and bring that back to normal too. but your stock (sized) timing belt will work, just make shure that the engine, cams and distributor are at tdc when you put it all back together.
Old Sep 27, 2004 | 08:02 AM
88crxb16a's Avatar
Default Re: (grndcont)
Come on guys i need some help What could my problem be?
Old Dec 16, 2004 | 04:33 AM
310BHPB16's Avatar
Default Re: (88crxb16a)
when you increasw the deck height by using a THICKER HeadGasket you have to adjust the cam gears to compensate
you add 1 degree Advance in cam timing
for every .012" increase in deck height
a Standard 3 layer gasket is .029"
you say you have a 2 mm gasket
Therefore 2 mm= 0.0787401574
0.029 (the height of standard gasket)
= 0.0497401574 then divide this by 0.012 (to get the advance in timing )
=4.145001311666
So in a nutshell Advance your cam pulleys by 4.1 Degrees
let me know how it goes
Modified by 310BHPB16 at 5:51 AM 12/16/2004
Old Dec 16, 2004 | 06:48 AM
mrx's Avatar
mrx
Default Re: (310BHPB16)
if the car don't run i think you have another problem. i run a stock b16 with a 3mm HG without cam gears or some ****... just put the distributor 2° retard but that was only to avoid detonation under high boost because of shiddy engine management.
maybe you have some vacuum problems when you say the car starts but stalls imidiatly.
i can't beleave that it has something to do with the gasket or the distributor... mine was running even if i turn the distri. from one end to the other...
what did you change on the engine management or is it stock? where did you connected the map sensor? all sensors connetec? changes in vacuum lines?
Greets
Malte.
EFjoe91
Jan 20, 2010 10:01 AM
NumberB
Apr 12, 2005 11:44 AM
88crxb16a
Sep 27, 2004 08:04 AM
tteg94
Jul 9, 2004 01:10 PM
