Timing advice needed
Old Dec 21, 2008 | 01:16 PM
bua's Avatar
bua
New User
Default Timing advice needed
Hi all.
The problem is that the car doesn't accelerate above 6500 RPM at boost.
I've build soft hmt on stock d16a9 crx II gen. It's my first one.
It keeps 6 PSI till rev limit. AFR is 11.5 at boost.
I've tune timing with linear retard option in TE.
I suspect that i should advance the timing in higher revs,
but, I'd appreciate if someone could look at the attached bin and write down some small hints.
File Type: zip
miro_gt
Sep 19, 2005 02:17 PM
xcountrirunr
Dec 1, 2004 08:57 AM
bmm89
Nov 21, 2004 08:17 PM
Btothe3rdDegree
Nov 12, 2004 04:53 PM
rudebwoy
Mar 29, 2003 08:55 AM
