throwing code 16??? need help!
Old Aug 21, 2009 | 06:00 PM
ctr32's Avatar
Default throwing code 16??? need help!
hey guys Im getting a code 16 popping up on my s300. there brand new precision injectors 880cc. its miss firing, has a limiter at 3000...have no idea whats goin on? any help would be great guys thanks!!! heres my build
92 civic
96 b18b1
>>eagle rods
>> JE pistons(9:1)
>> Port and polished head
>> Feera valves
>> Crower cams
>> skunk2 cam gears
>> Crower retainers
>> Crower springs
>> edelbrock X intake manifold
>> AEM fuel rail
>> AEM fuel regulator
>> Block guard
>> a/r.70
>> 3"downpipe&exhaust
>> tial38mm wastegate
>> Walboro 255lph HP fuel pump
>> ARP head stud
>> precision 880cc
>> omni 3 bar
on e85
s300
Old Aug 21, 2009 | 06:46 PM
SilverEk3dr's Avatar
Default Re: throwing code 16??? need help!
Usually if that happened to me its cause one of the injector clips came loose. You can disable the code in the s300, but if its misfiring then there really is a problem(loose wire etc).
U got a resistor box installed?
Old Aug 21, 2009 | 07:21 PM
RedneckRicer's Avatar
guessing you didnt install a resistor box or a injector driver. if you did install it then you didnt install it right.
Old Aug 21, 2009 | 08:35 PM
narfdanarf's Avatar
Had a similar issue once, turned out to be the map sensor.
Old Aug 21, 2009 | 11:29 PM
ctr32's Avatar
have resistor box installed
Old Aug 22, 2009 | 07:27 AM
ctr32's Avatar
bump
Old Aug 23, 2009 | 08:44 PM
ctr32's Avatar
brand new omin map sensor
Old Aug 23, 2009 | 08:46 PM
ctr32's Avatar
i'll drive it around for 10-20 mins starts breaking up, then eventauly it will go away sometime not.....what you guys think is going on? Main relay? fuel filter? have resistor box its installed correctly cause it was on my last setup. maybe on of the wires are backwards? anything would help thanks guys!!!
Old Aug 24, 2009 | 07:17 AM
ctr32's Avatar
bump!!
Old Aug 24, 2009 | 08:41 AM
ctr32's Avatar
any other input guys??
Old Aug 24, 2009 | 12:06 PM
ive had issues with resistor boxes not installing the same all the time make sure you are getting positive voltage on the supply. My friend did it the same that i did on my car same pins ended up frying a part of his ECU cause he didnt do a voltage check on his wiring and had 2 injectors not work right.
Old Aug 24, 2009 | 01:11 PM
ctr32's Avatar
hmm well its a new ecu....when i took the car to get tuned the ecu was bad and they replaced it...so its probably the resistor box huh? it came wired already soo idk if its hooked up wrong or what
ctr32
Engine Management and Tuning
Aug 24, 2009 05:11 PM
TheCheeseWedge
Jun 3, 2007 10:48 PM
JDM Jimmy
Mar 14, 2004 01:35 PM
HONDABOND
Nov 9, 2003 12:59 AM
