Throttle body question
Old May 5, 2007 | 10:56 AM
BDaTurboTeg's Avatar
Default Throttle body question
im thinking about buying a skunk 2 pro series intake manifold.....
whats a good throttle body to match?
this is on 96 stock turbo LS
Old May 5, 2007 | 05:58 PM
bump..............................
Old May 6, 2007 | 06:16 AM
sunday bump...
Old May 21, 2007 | 01:25 PM
Blueprint's Avatar
Default Re: Throttle body question (BDaTurboTeg)
either skunk2 to match, or Aebs 68mm for the price, or RPM service for the BLING
Old May 21, 2007 | 08:28 PM
ok thanks..this is kinda far in the future so im just kinda learning where to get things and what matches what
Old May 21, 2007 | 10:46 PM
turbohf's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BDaTurboTeg &raquo;</TD></TR><TR><TD CLASS="quote">
stock is fine...
Old May 22, 2007 | 08:37 AM
1158's Avatar
I have the Skunk2 Pro series manifold and here is what I did. Get an extra stock TB, but you have to get one that is 60 mm. I forget exactly which ones are that size, but you can find them all over.
Do a search for a guy named Maxbore or check out his website, Maxbore.com. He can bore stock TBs out 4mm. I think he charges 100 shipped back to you, so for a toal of $150 I got a 64mm TB that matches the intake (Pro Series is 64mm). Then all you need is a Type R TB/mani gasket and you are set. Again, I only did this because I knew the Pro Series manifold opening was 64mm and I wanted everything to flow smoothly.
Old May 22, 2007 | 07:32 PM
Default Re: (1158)
thats awesome might keep that in mind
Old May 22, 2007 | 08:13 PM
inspyral's Avatar
You can also get a brand new Professional Products 65 or 68mm throttle body for about $135/$147.
Old May 22, 2007 | 08:52 PM
1158's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inspyral &raquo;</TD></TR><TR><TD CLASS="quote">You can also get a brand new Professional Products 65 or 68mm throttle body for about $135/$147.</TD></TR></TABLE>
True, but Maxbore does a hell of a job. It's a stock part, he sets your tps before he sends it back and the TB has a lifetime warranty. So if the throttle plate starts sticking...which seems to happen a lot with aftermarket TBs, he'll fix it. If you can be with out your car for a week or so you won't need to buy another TB and you can send him yours...costing you $100. When I sent mine the turn around time was amazing.
Rus1an
Sep 4, 2010 07:06 AM
ShinkospeedEM1
18
Mar 27, 2008 08:16 PM
mortificationrock
17
Nov 13, 2007 06:49 AM
BDaTurboTeg
May 5, 2007 10:55 AM
McFlurry
Jul 6, 2006 05:31 PM
