Throttle Bodies!!!!
Old Sep 26, 2002 | 09:39 AM
Boostless97Lude
Guest
Posts: n/a
Default Throttle Bodies!!!!
what is the best TB to use on a turbo apllication, specifically an H22
Old Sep 26, 2002 | 10:39 AM
Spade's Avatar
Default Re: Throttle Bodies!!!! (Boosted97Lude)
Typically the larger the better.
70 MM
Old Sep 26, 2002 | 11:01 AM
Boostless97Lude
Guest
Posts: n/a
Default Re: Throttle Bodies!!!! (Spade)
yeah, i knew that much already, i was looking for manufactuers names actually, but thanks anyways
[Modified by Boosted97Lude, 3:01 PM 9/26/2002]
Old Sep 26, 2002 | 11:03 AM
paulzy's Avatar
I have a 68mm TB off of a mustang if you'd like....I never used it. How does 60 bucks shipped sound?
Old Sep 26, 2002 | 11:36 AM
Boostless97Lude
Guest
Posts: n/a
Default Re: Throttle Bodies!!!! (paul_vang)
sorry, but i really don't like the idea of using a crustang part on my car
Old Sep 26, 2002 | 01:30 PM
Smashback's Avatar
what does it matter as long as it works? do you just want to spend more money for the same thing?
Old Sep 26, 2002 | 02:27 PM
Boostless97Lude
Guest
Posts: n/a
Default Re: Throttle Bodies!!!! (Hatchblack)
i don't know..... i personally have NEVER had good luck with any Ford products, i don't know if it's just my body chemistry or what. even when i drive my friends Cobra that runs good as f*ck, something always seems to happen whenever i drive it. so i'd rather be safe and buy something meant for my car
Old Sep 26, 2002 | 03:35 PM
turbo Si's Avatar
A ford throttle body does fit on our manifolds. What year should I look for. My cousin has a 351 Windsor, maybe i'll ****** his! What about the sensors on our throttle bodies (TPS i believe), will they work on a ford tb?
Old Sep 26, 2002 | 04:29 PM
ion_four's Avatar
Default Re: Throttle Bodies!!!! (turbo Si)
I think you have to swap the sensors for honda, I think that the mounting has to be modified a hair, but I could be wrong on that. I assume you're not sticking this on a stock manifold? if so, then it won't do much good at all.
BB4_JDM
Mar 8, 2009 06:31 PM
hamadiscool
Jan 15, 2007 08:37 AM
darockstar
Jul 20, 2006 08:15 AM
oem_dc2
Apr 7, 2004 11:08 AM
schwett
Apr 28, 2002 09:06 AM
