Thoughts on my possible setup?
Old Aug 16, 2002 | 06:39 PM
Pinhead's Avatar
New User
Default Thoughts on my possible setup?
This will go in a daily driven '93 Del Sol. any changes you see fit just chime in.
Motor-
B18c1 Bottom End
New Bearings/Gaskets/Pumps etc....
JE or Endyn Pistons 81.25 (would like an overall compression of 9.3)
Eagle rods
ARP head bolts
B18c1 Head
stock except for 1mm oversized SS Ferrera exhaust valves
JG/Edelbrock Intake Manifold
Gsr Tranny w/CM4 or Action Clutch, ITR flywheel, and Quaffe LSD(if I can afford it)
And of course your basic turbo kit which will be ordered from 2k Teg
I plan on boosting 12-14psi daily on pump gas and 17-18psi Race gas.
any thoughts?
oh, and Hondata stage 2b
[Modified by Pinhead, 10:40 PM 8/16/2002]
[Modified by Pinhead, 10:41 PM 8/16/2002]
[Modified by Pinhead, 12:06 PM 8/18/2002]
Old Aug 16, 2002 | 06:56 PM
AlphaKennyWun's Avatar
Default Re: Thoughts on my possible setup? (Pinhead)
You could sleeve the block...
Old Aug 16, 2002 | 06:57 PM
VaporTrail's Avatar
New User
Hey man I really like this setup. Ditch the ITR flywheel, you dont need it. Definately Quaiffe!
Old Aug 16, 2002 | 07:07 PM
Pinhead's Avatar
New User
Default Re: Thoughts on my possible setup? (VaporTrail)
Gotcha Wow, I impressed John lol.
I'm hoping for 300-325whp on the pump gas and 375-400whp.
I figured I don't need any head work because I don't plan on revving past 8500 or so.
and I think I might even grab a 2nd car. Possibly a CRX and swap in a siR motor.
Oh and should I bother sleeving? how much higher can I boost if I do?
Old Aug 17, 2002 | 06:55 PM
Pinhead's Avatar
New User
ttt, please
Old Aug 17, 2002 | 07:24 PM
HybridKOOP's Avatar
I never knew there was anyone on this earth more indecisive than myself.
Old Aug 17, 2002 | 07:36 PM
Pinhead's Avatar
New User
Default Re: Thoughts on my possible setup? (HybridKOOP)
Oh, I am the KING of Indecisiveness.
Old Aug 17, 2002 | 09:13 PM
ekb18c's Avatar
looks good to me! What compression did you say you going to run? You said overall compression of 81.25 but im sure that's a typo.
If your planning to run high boost I would recommend to sleeve that baby! And if you were planning to make ~400whp then you might want to consider getting a bigger turbo. I mean you can make ~400 whp with a t3/t4oe but it would be easier if you used hmm let's say 60-1.
Just my $.02
Old Aug 18, 2002 | 08:06 AM
Pinhead's Avatar
New User
Default Re: Thoughts on my possible setup? (ekb18c)
I have a T3 60-1 sitting in my living room, you think that'll handle 400whp?
Old Aug 18, 2002 | 08:29 AM
I think that will handle close to 500 whp with race gas but will your motor handle it?
I wanted exactly what you wanted but cracked a sleeve.
read here https://honda-tech.com/zerothread?id=256851
I would definately sleeve the block with your goals.
[Modified by SO3Burner, 12:34 PM 8/18/2002]
Old Aug 18, 2002 | 08:41 AM
ekb18c's Avatar
Yup the turbo will produce that power! The question is will your motor handle it? you will be runnign an external pump right? Or atleast I hope you will be runnign an aeromotive fuel pump.
Old Aug 18, 2002 | 08:54 AM
Pinhead's Avatar
New User
yes, all fuel will be taken care of. I don't know an incredible amount of info on turbocharging and what it requires, but John (vaportrail) will be doing the swap and helping me with everything and tuning it for me.
Old Aug 18, 2002 | 02:05 PM
ekb18c's Avatar
Then your in good hands! Have fun with your new setup!
Old Aug 18, 2002 | 02:34 PM
tygsr's Avatar
sounds like a good set up, very similar to mine. What injectors are you going to use? I would suggest an in-tank fuel pump(walbro) and while your motor is apart. do a port and polish and a valve job. as far as sleeving goes, their is a huge debate on whether or not you should sleeve, if you have the money and down time to spare, then of course do it! IF not, with the proper fuel managment and only running high boost on race gas, your sleeves will hold up for a while...I no a guy who had 470 whp on a gsr and ran multiple low 11 sec passes at 3500 feet elevation!! NEver cracked a sleeve...but it is nice to have that peace of mind...
Old Aug 18, 2002 | 02:40 PM
BoostedED9's Avatar
pinhead: what area in orlando do you live in?????
Old Aug 18, 2002 | 02:42 PM
Pinhead's Avatar
New User
Default Re: Thoughts on my possible setup? (ED9Hybrid)
ucf area.
Old Aug 18, 2002 | 02:43 PM
BoostedED9's Avatar
any pics of your car, i prob seen you around....
Old Aug 18, 2002 | 02:57 PM
Pinhead's Avatar
New User
right now I'm driving around a '02 Camaro Z28, but I used to have a '00 FBP Type R.
Eklsv-t
18
Jan 7, 2008 05:35 AM
drunknbass
12
Feb 8, 2005 04:07 AM
quickergixxer
Jan 16, 2004 04:40 PM
RAAZ227
Feb 20, 2002 02:32 PM
B_CRUZ!
Jan 16, 2002 07:56 PM
