Thought I'd ask u guys...
Old Jun 27, 2002 | 07:39 PM
legendboy's Avatar
Default Thought I'd ask u guys...
Everybody seems to know alot here, Will a afc II or a s-afc work on a B18b engine? Apexi information only gives instructions for B18C's. Guy I bought it from said no prob....I have it hooked up right but it runs like ***.
Old Jun 27, 2002 | 07:48 PM
Reverend's Avatar
Default Re: Thought I'd ask u guys... (legendboy)
I don't know for sure, but I would think it would be the same, as long as you don't hook up the wires for the vtec.
Old Jun 28, 2002 | 03:19 AM
kinesistech's Avatar
Yes it works. What did you do wrong?
Old Jun 28, 2002 | 06:17 AM
legendboy's Avatar
Default Re: Thought I'd ask u guys... (kinesistech)
4 wires on afc, white, yellow, red & black.
White wire is hooked up to harness side of map wire 3rd top from right pin on C
Yellow is on ecu side of map wire "
Red is on IG wire Top right of A
Black is sensor ground---Top right pin of C
[Modified by legendboy, 8:18 AM 6/28/2002]
[Modified by legendboy, 8:19 AM 6/28/2002]
Old Jun 28, 2002 | 08:08 AM
PrecisionH23a's Avatar
www.apexi-usa.com
download the instruction manual.
Old Jun 28, 2002 | 08:46 AM
legendboy's Avatar
Default Re: Thought I'd ask u guys... (GudeH23a)
I have the afc wires backwards on map , I took out the afc and jumped the wires (yellow and white) and its still throwing code 3 and running rich with out the afc. I hope I didn't fuc anything. Could this screw my map sensor? I have switched the wires and it still won't work right, with or without the afc......
[Modified by legendboy, 1:43 PM 6/28/2002]
Old Jun 28, 2002 | 11:43 AM
legendboy's Avatar
Fixed! I am dumb.
[Modified by legendboy, 2:06 PM 6/28/2002]
Kahuna9889
Apr 5, 2009 05:57 PM
WannaHonda
Aug 5, 2004 01:22 PM
omahaturbocivic
Aug 31, 2003 10:46 AM
xXx Justin xXx
Jun 18, 2003 09:49 AM
This One
Feb 2, 2003 04:20 AM
