To those running 11s or better:
Old May 26, 2006 | 11:08 AM
Mr. Vapor's Avatar
Default To those running 11s or better:
Care to share what your axle/tire/tranny/traction bar set up is?
im starting to build up the next weakest link and i dont dare launch on my OEM axles on slicks.
just curious to see if all the 'stories' ive heard are just myths or indeed facts.
Old May 26, 2006 | 11:11 AM
quicksilver1689's Avatar
i ♥ snails
If your car is capable of running 11 secound 1/4 miles then you should very well look into the drivetrain setup. Oem axles can take a beating but its just a matter of time before they break and leave u screwed. Full race or z10 traction bars, maybe some stage 3 axles, gsr tranny is always nice with boost.
Old May 26, 2006 | 11:17 AM
Mr. Vapor's Avatar
Default Re: (quicksilver1689)
to late....broke (well more like bent/tweaked my inner joint) the other night and now im rebuilding but im looking to set up a plan of purchases, not just buy the wrong parts. whats been proven to work.
Old May 26, 2006 | 11:31 AM
fjt's Avatar
fjt
i know i havent run 11s yet but the car has the opotential to do it..
Anyways...
Stock Axles, no traction bars, 22 X 8 13" rim MH Slicks.. Y8 tranny.
Have another friend with same setup and 11.8sec runs with Stock axles,no traction bars and slicks
Old May 26, 2006 | 11:33 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: (Mr. Vapor)
First Off i broke an inner on the pass side this weekend at atco, but glen is going to warranty it. every pass up untill the last one was fast shifting, off gas in clutch, off clutch in gas. the pass i broke mine was on the 1-2 gas to the floor push clutch yank. so on to my setup:
axles:
gator racing stage III modifieds
clutch:
exedy twin
diff:
quaife
tranny:
all stock but gearspeed syncros
bars:
full race
slicks:
24.5 x 8.5 x 15 m&h racemasters
rims:
15 x 8 bogart I 10's
suspension:
progress drag
best 60' 1.68 in my 10.72 run.
Old May 26, 2006 | 11:36 AM
mrbsponge's Avatar
DSS stage 3s
ITR diff
KYB AGXs
**WEAPON R COILOVERS** hahaha
1.61 60ft
Old May 26, 2006 | 12:27 PM
JDMs1eeper's Avatar
Default Re: To those running 11s or better: (Mr. Vapor)
I ran stock OEM axles for 2 years on 130+ launches on slicks. Many are 1.75 or faster 60ft times. No traction bars. Best 60fts were 1.68-1.69 .
LS turbo, LS tranny, Launch control at 6,000
25x8x13 M&H slicks w/ 9psi of pressure.
7,800rpm revlimit
Ran 11.3 @ 124 w/ no 4th gear switching to a lovely LS 5th gear
2LiterTurboSeR's Avatar
Default Re: (mrbsponge)
A friend running a turbo LS Hatch running stock axles, ls tranny and no other traction mods on 24.5 slicks went 11.65 @ 118 with a 1.7 60 ft.
Old May 26, 2006 | 02:24 PM
H.A.R.T B18C1EG6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrbsponge &raquo;</TD></TR><TR><TD CLASS="quote">DSS stage 3s
1.61 60ft</TD></TR></TABLE>
haha that actually made me laugh
nice 60ft...
Old May 26, 2006 | 02:31 PM
mrbsponge's Avatar
Default Re: (H.A.R.T B18C1EG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H.A.R.T B18C1EG6 &raquo;</TD></TR><TR><TD CLASS="quote">
nice 60ft... </TD></TR></TABLE>
thanks, the coilovers came with the car when i bought it.
i have some custom rate ground controls for it, for drag racing but im scared to change the set up cause it works so well
no traction bars either, people talk about wheel hop but i guess i either havent experienced it or just dont know i have...... i like thge car to spin just a tad, it helps keep from breaking stuff
also i use the Ebrake/staging brake to preload the car
Old May 26, 2006 | 02:35 PM
vaporboy12's Avatar
gator stage 2s
gsr tranny open diff
exedy twin
24.5x9x13 mt's
13x3 weld racelights
omni drag suspension full-race pro-ams not installed yet
10.65@135 1.79 60foot
60 should be runner but that was my first pass in the car this season... 20psi straight out of the hole due to no boost controller
Old May 26, 2006 | 02:55 PM
RyanEJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Vapor &raquo;</TD></TR><TR><TD CLASS="quote">Care to share what your axle/tire/tranny/traction bar set up is?
I haven't run 11's yet, but I can tell you that slicks are easier on axles than street tires. Street tires can tend to hop which is what really kills axles.
Old May 26, 2006 | 03:19 PM
mrbsponge's Avatar
Default Re: To those running 11s or better: (RyanCivic2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanCivic2000 &raquo;</TD></TR><TR><TD CLASS="quote">
I haven't run 11's yet, but I can tell you that slicks are easier on axles than street tires. Street tires can tend to hop which is what really kills axles.</TD></TR></TABLE>
very true, and more people break axles on drag radials as well, due to the NON wrinkleing effect and weight, DRs are heavy
Old May 26, 2006 | 03:56 PM
.RTErnie's Avatar
Default Re: To those running 11s or better: (mrbsponge)
Koni adj. struts
ebay coilovers/ H&R Racing springs
M&H 25x9x13 slicks
Diamond racing wheels 13x8
DSS Stage 3 axles
near solid motor mounts
PG Locker
3.55 transmission
the thing that kept me from breaking axles...proper engine alignment in the chassis...keeping the motor from rocking/moving, keeping the axles perfectly perpendicular to the trans case, etc
Thing that helped my 60' the most...corner balancing my car.
1.66 60' and did a 7.5@99
i later did a 11.80@124 (only 1 pass and it was shitty)
Old May 26, 2006 | 07:53 PM
JDMs1eeper's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanCivic2000 &raquo;</TD></TR><TR><TD CLASS="quote">I haven't run 11's yet, but I can tell you that slicks are easier on axles than street tires. Street tires can tend to hop which is what really kills axles.</TD></TR></TABLE>
yeah, my friend in the past 2 months has broken 2 diff's and 5 sets of axles on his BFG's. including a set of stage3 axles.
ran a 10.98 @ 127 on slicks w. stock axles and stock open diff.
Old May 26, 2006 | 10:12 PM
turbotime's Avatar
tim you just dont know how to drive!
OEM axles are fine just get teh autozones and some traction bars and youll be good. My guess is the axles dont break becuase of shear power its cause of the wheel hop and the angle they are being forced into that they are breakin....
but if im wrong i say stage 3 axles
Old May 27, 2006 | 04:25 AM
DaveF's Avatar
Default Re: (turbotime)
mt 28x10.5's, advance design coilovers, home made traction bars/ and wheelie bars 1.38 60ft. leaving @ 7200 around 10-15 psi out of the hole.
http://www.nitrodriveline.com best **** around.
Old May 27, 2006 | 07:07 AM
Boostin Ex's Avatar
Default Re: (dturbocivic)
I run Tein SS coilover, stock axels, stock jdm lsd, clutch specialties clutch, M/T 24.5x9x13 slicks my car went 11.3 @130mph with a crappy 60ft
Boostedb20EH2
Feb 25, 2008 04:55 AM
93FastLs
Oct 31, 2004 01:34 AM
BauleyCivic
Sep 11, 2004 09:49 PM
98civicEX
May 20, 2002 10:56 PM
paulzy
Nov 15, 2001 01:40 AM
