Think I found the problem...
Old Jun 21, 2003 | 07:14 PM
Tinker219's Avatar
Default Think I found the problem...
K, I had my gf jump in my car to crank it over while I checked things out.
Setup:
JG LS 81mm block, t4/60-1 turbo, AEM EMS, custom Intake manifold.
Well, I kept losing spark a whole nightmare. I tried a different basemap, and everything is kosher with that.
So while my gf was cranking, i notice that the timing belt pulley hops up and down at least a half inch!? WTF? A couple weeks ago, we heard this big "THUNGGGGG", I thought it was just something seating.
Well aparently, the timing belt pulley on the crank skipped over the keyway, and now it is STUCK on there. Has this happened to ANYONE else?
Tomorrow Im going to cut the ****** off, because its not going to just "come off"...
Old Jun 21, 2003 | 07:30 PM
Farnsrocket's Avatar
Default Re: Think I found the problem... (Tinker219)
Damn, was it the right key?
Old Jun 21, 2003 | 07:42 PM
Joseph Davis's Avatar
Default Re: Think I found the problem... (Farnsrocket)
THe timing gear key is built into the timing gear on the LS. The independant key that you fit on there is for your crank pulley.
Something is very badly fucked here.
Old Jun 21, 2003 | 07:46 PM
APZGSR's Avatar
Default Re: Think I found the problem... (J. Davis)
you'l have to replase the oil seal cause it will burn.
Old Jun 22, 2003 | 05:30 AM
Tinker219's Avatar
Ya, the keyway broke or something...Im absolutely stumped...Im going out this morning to try and bust the **** off.
Im not being a snott, but how would the oil seal burn if the timing belt pulley skipped its keyway? Thanx
Old Jun 22, 2003 | 07:42 AM
Tinker219's Avatar
note to self....keyway on the timing belt pulley goes "out"
Still wont start though.
With the 3bar Map Sensor, the load scale is -14.7 to 29.something. Just sitting there, it says Im at -2(which is almost halfway up the load scale). Should I change the Map Min? I dont have a vaccum pump or anything, so I just went by a few other peoples suggestions on the EMS board.
Old Jun 22, 2003 | 10:00 AM
Foozball26's Avatar
edit: ah timing gear, mixed the two up
brain wasnt working straight at 1 am after work all day
Modified by Foozball26 at 5:41 PM 6/22/2003
Old Jun 22, 2003 | 11:46 AM
Tinker219's Avatar
Default Re: Think I found the problem... (Foozball26)
the timing gear is fixed though...there is a key, but its for the crank pulley only. Honda prolly did this to avoid "accidents" by not putting the keyway in the timing gear.
ya, when you put it on backwards, it doesnt work either
1320london
Jul 29, 2017 02:55 AM
excaliburcombo
Feb 13, 2016 03:26 AM
suje
14
Feb 22, 2012 04:19 PM
HBK
Sep 1, 2005 09:37 AM
Jonathan_ED3
Apr 12, 2003 02:55 PM
