Thicker head gasket or no?
Old Aug 1, 2002 | 09:02 AM
integra-modder's Avatar
Default Thicker head gasket or no?
Cometic and InlinePro both have 3mm head gaskets...
Is it better when to get one of these and run a stock compression engine or is it better to keep the stock gasket and get lower compression pistons?
Old Aug 1, 2002 | 09:14 AM
FOrSfEd's Avatar
Default Re: Thicker head gasket or no? (integra-modder)
Either way would be good, I have a cometic and it works pretty good but I think I would honestly spend the money to get the low com pistons.
Lee
Old Aug 1, 2002 | 09:44 AM
DC2R714's Avatar
Default Re: Thicker head gasket or no? (Rex2nv)
You have a GSR 9.5:1. My friends gsr runs with stock headgasket and 10psi with no problems.
Old Aug 1, 2002 | 03:39 PM
Default Re: Thicker head gasket or no? (DC2R714)
i want to go more than 10
im looking at 350-400 whp
Old Aug 1, 2002 | 03:50 PM
jinxproof99's Avatar
New User
you'll make 350 to the wheels easy. inline pro 3mm headgasket. afc/fmu/440 injectors/race gas and tuning. stock internals.
Old Aug 1, 2002 | 08:04 PM
Default Re: Thicker head gasket or no? (jinxproof99)
im taking daily driven
i dont care about race gas and **** because when i see a car on the road (not that i street race or anything ), I dont want to be running out of my car and pouring in some octane booster.
Im going FI with pistons and rings, so should I keep stock compression pistons in the situation that I need to take the turbo off for some stupid reason
Old Aug 1, 2002 | 08:25 PM
Etylorcen's Avatar
Well stock compression on the b18c isnt that high as it is so if you get forged pistons staying around the same compression will be fine. You'll make a little more power and spool faster.
Old Aug 2, 2002 | 07:53 AM
Default Re: Thicker head gasket or no? (Etylorcen)
but then i need a really good tunner to be able to tune it so there is no detonation, right?
and in your set up, do you suggest getting the thicker gasket or no?
Old Aug 2, 2002 | 08:46 AM
supergreenNA1's Avatar
New User
definitely go the piston route if you seriously plan on making 350whp. at fmax we produced 350whp @15psi on a stock b16 but it only lasted a few runs. melted a piston.
Old Aug 2, 2002 | 01:09 PM
Default Re: Thicker head gasket or no? (supergreenSol)
cool...
what do you suggest for a compression? im a noviece (i know that spelling is wrong) tunner, so keep that in mind
Old Aug 2, 2002 | 02:27 PM
New User
i wouldn't drop a street driven gsr any lower than 9.5:1... but i'm sure many would disagree with me. i went 10:1
Old Aug 2, 2002 | 09:52 PM
so I should shoot for 9.5:1 then?
Old Aug 3, 2002 | 02:50 AM
Cyber ITR's Avatar
was that with a thicker headgasket ???? and it still melted a piston ??
cheers
pootie.teng
18
Mar 6, 2007 03:23 PM
NathanMorris
Jul 28, 2006 05:59 PM
iceman95
Mar 2, 2006 09:24 PM
jazz1320
Mar 13, 2004 10:57 AM
