Are these plugs ok for my application
Old Jun 11, 2002 | 03:39 AM
Hybrid's Avatar
Default Are these plugs ok for my application
SOHC vtec, TD05-14b, IC. Mild street application, 10psi boost max. Arias low comp forged pistons.
I'm using NGK BCPR6-E plugs right now.
Will they work good or give me headaches. The stock plug is ZFR5J-11 I think. Should I just use that plug but go to a 6 or 7 heat range?
Old Jun 11, 2002 | 04:33 AM
RGAZ's Avatar
New User
Default Re: Are these plugs ok for my application (Hybrid)
If stock is 5 series, 6 should be fine. 7 may be too cold, but it depends on your intake temps and you compression. How low is low compression? If its like 8.5:1 or lower, then stick with the 6 series, they should be just fine to 10 psi.
Randy
Old Jun 11, 2002 | 09:04 AM
Hybrid's Avatar
Default Re: Are these plugs ok for my application (RGAZ)
thanks for the reply man.
89si-rex
33
Oct 9, 2013 11:20 AM
Black R
Feb 9, 2005 07:05 PM
PoWeRBaN_PaNdA
Nov 1, 2002 09:11 AM
canuck-mx6
Jun 19, 2002 07:35 PM
RJL
Dec 12, 2001 10:11 PM
