Are these 440cc Precision Injectors???
First off, I want to know if i have precison 440cc or not, bought them brand new off a site on ht here. It's high ind. 440cc. Two have a number 1927 and t wo have 1917. ALso they all have the numbers 01D0308 on them. Does it matter which hole it goes in or do they have certain spots where their suppose to go? Well i installed them on my car anyways, had to force the fuel raill in a little bit because i used the two stock o-rings. The Car idles well but when i step on throttle alittle bit it bogs than revs. So far no leaks. Everythings stock, i haven't install my fuel pump yet, could that be the problem? Could it be too rich?
Modified by Chee_dog at 6:58 PM 10/6/2007
1. what EMS do you have?
2. show some pics
3. hope you are not running bigger injectors with stock fuel map
4. never put anything on your car without knowing what it can do or cannot do or you will hurt your motor.
2. show some pics
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX T-Si »</TD></TR><TR><TD CLASS="quote">
It sure sounds like it.
You need to give more info than what you provided
boostincoupe
Dec 15, 2004 05:17 AM
