Teflon on flared fittings....
Old May 23, 2006 | 11:45 AM
hondaeg8's Avatar
Default Teflon on flared fittings....
Do any of ya'll use teflon on flared fittings? like for the oil return and oil feed lines?
i'm having a oil leak problem from my oil return line right now and i'm trying to figure out how to get it to stop leaking. i didn't use any teflon on either fittings, but i did use it on the oil feed line. i'm using Stan's oil return line kit so i have the AN fittings.
i have the oil line off right now, so do i put teflon on the fittings and put the oil line back on?
Old May 23, 2006 | 11:47 AM
dpetro1's Avatar
Default Re: Teflon on flared fittings.... (hondaeg8)
teflon on npt/bspt fittings, not on flared or AN fittings.
Old May 23, 2006 | 11:48 AM
RCautoworks's Avatar
Just be careful because teflon can cause blockage. They also sell teflon tape in a tube, works good.
Old May 23, 2006 | 11:50 AM
LSEGHATCH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dpetro1 &raquo;</TD></TR><TR><TD CLASS="quote">teflon on npt/bspt fittings, not on flared or AN fittings. </TD></TR></TABLE>
How come you don't use teflon on the AN fittings? I've seen it done before and I'm curious why you wouldn't.
Old May 23, 2006 | 11:53 AM
trickeng's Avatar
Default Re: Teflon on flared fittings.... (LSEGHATCH)
you don't use it because if the fitting is leaking it is not working properly.
a flare fitting seals using the taper of the flare not the treads.
stackz
Feb 28, 2008 01:49 PM
LSEGHATCH
Sep 6, 2007 02:40 PM
delslowh23
Feb 28, 2004 04:59 PM
rhettster
Jul 9, 2003 08:40 PM
rpm9100
Jun 13, 2003 03:55 PM
