Tease Update
Old Aug 18, 2003 | 05:35 PM
  #26
meanteg's Avatar
New User
Default Re: Tease Update (Cramerox)
You got a Zex single fogger dry kit ? not good, not good.
change for a wet kit.
Old Aug 18, 2003 | 05:49 PM
  #27
racecarpete's Avatar
Default Re: Tease Update (meanteg)
T66? What are your goals?
Old Aug 18, 2003 | 06:15 PM
  #28
PrecisionPerformanceParts's Avatar
Default Re: (blue99turbo)
We drove it about 10 miles on Saturday, it started raining and I had it too rich in vacuum so it fouled out the plugs. I have been a littled burned out on cars lately, so I have not messed with my map very much. I don't have an EX cluster laying around, I have a GSR cluster, but I don't think it would plug up. Oh yea, I think the main relay may be going out on the car, because it was acting up on Sunday, furthering my disdain for cars lately.
Old Aug 18, 2003 | 06:19 PM
  #29
Thanks for the tips, but the nitrous is direct ported underneath the manifold. I have 4 Nos jets. The fuel will be controlled by the AEM with the nitrous fuel map. I flip the switch and it sends the signal to the aem, and runs the nitrous fuel map when activated, then the boost gets up and the pressure switch cuts the signal to the box and the aem and back to basic map. The stainless line you see tapped into the AEM is for the methanol injection from derekdevises.com. I like the dry set up because it is less likely to back fire.
Old Aug 18, 2003 | 06:23 PM
  #30
bambooluv's Avatar
Default Re: Tease Update (fatkid)
very nice....
Old Aug 18, 2003 | 06:25 PM
  #31
nevin's Avatar
thats crazy! What chassis is that in?
Old Aug 18, 2003 | 09:05 PM
  #32
1titesol's Avatar
Default Re: (nevin)
Glad to see that most is done. All that hard work will payoff the day you tune it. And all my hard work will payoff at night. I cannot wait til this thing is on the track/street. Good job, and good luck Kevin.
Old Aug 18, 2003 | 09:09 PM
  #33
Shawn C's Avatar
In The Garage
very nice kevin, very nice. i hope it runs as well as you hope. i was always wondering though, why didn't you run an 8 injector setup? instead of those big *** *****? oh well, i'll have to see it next time i'm up in k-town. good luck
-Shawn
Old Aug 18, 2003 | 10:37 PM
  #34
OPIE99SI's Avatar
i love it but i have seen with my own eyes it looks lots beter in person . pics does not even come close to what it really is.got to love it looks good
Old Aug 18, 2003 | 11:40 PM
  #35
psileepR's Avatar
New User
Default Re: Tease Update (OPIE99SI)
i can see you have no problems in the power dept.
What are you going to do to get the power to the ground? traction bars? slicks?
sick car!!!!
Old Aug 19, 2003 | 05:32 AM
  #36
Jeff C's Avatar
Looks good Kevin.
Old Aug 19, 2003 | 07:11 AM
  #37
91CivicSi's Avatar
Looks good...for me to poop on!!
I may come down tonight (Tues.) to check out the progress.
Old Aug 19, 2003 | 02:14 PM
  #38
2001teggsr's Avatar
i looks ok....i think it would be better if you let Buster lay on top of it and dry hump it awhile
Old Aug 19, 2003 | 02:22 PM
  #39
R6Elmo's Avatar
Default Re: (Jared)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jared &raquo;</TD></TR><TR><TD CLASS="quote">The turbo is what the bov is meant to protect, the closer the better it works.</TD></TR></TABLE>
Sorry, but that is a very WRONG statemnt. the closer the BOV is to the throttle body the better. You must remember that all the air is rejected back by the throttle body closing. If you put the BOV close to the turbo, the air basically hits the throttle body door and bounces back towards the turbo and then finally out the BOV there.
Old Aug 19, 2003 | 03:21 PM
  #40
nevin's Avatar
There is a thread somewhere that goes into great detail on how it performance wise really dosen't matter.
Old Aug 19, 2003 | 04:17 PM
  #41
Shawn C's Avatar
In The Garage
Default Re: (R6Elmo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R6Elmo &raquo;</TD></TR><TR><TD CLASS="quote">
Sorry, but that is a very WRONG statemnt. the closer the BOV is to the throttle body the better. You must remember that all the air is rejected back by the throttle body closing. If you put the BOV close to the turbo, the air basically hits the throttle body door and bounces back towards the turbo and then finally out the BOV there.</TD></TR></TABLE>
good point, but the bypass valve, or "blow-off valve" is supposed to be centered in the compression pipe, or just after the intercooler. this bleeds off pressure equally, and lets air in the IC cool more. sorry to ***** kevin, just givin a bump for others to see
Modified by 22lbGS-R at 11:55 PM 8/24/2003
Old Sep 21, 2003 | 07:48 PM
  #42
Plan B's Avatar
Default Re: (22lbGS-R)
Wow, i heard 475 hp this past weekend with slicks rubbing the fenders?
Mustang Dynos suck, I tried to find your car, but no luck.
-Brian
(shawns friend)
Old Sep 21, 2003 | 08:17 PM
  #43
nigel's Avatar
it sounds to me like its going to be like an 800 hp car. correct? what kind of car is it???? I am dying to know... and its it street driven?
Old Sep 21, 2003 | 10:05 PM
  #44
*Boostwerks*'s Avatar
I hope it doesn't kill you...
Old Sep 21, 2003 | 10:11 PM
  #45
Actually, He's right. I'm not saying that having the BOV at the TB will kill a turbo, but I'm simply saying in full technical terms, having a BOV right after the turbo or on the IC's end tank is the best place for it.
Think about it. The closer the BOV is to the turbo the faster it can evacuate the air coming from it. There is less pressure the compressor has to over come to push the air out the BOV, which keeps it at a higher RPM. There's a reason why Full-Race puts BOV flanges on the compressor side IC endtank.
Old Sep 22, 2003 | 04:16 AM
  #46
Muckman's Avatar
Moderator in Chief
Default Re:
Wow that setup is good for like a million HP!@!
Old Sep 22, 2003 | 04:58 AM
  #47
RacerXI's Avatar
Default Re: Tease Update (bambooluv)
I saw it. I didn't realize who the car belonged to though. Nice dyno run BTW.
Old Sep 22, 2003 | 10:01 AM
  #48
nigel's Avatar
dyno run? what numbers did he come up with?
Old Sep 22, 2003 | 01:09 PM
  #49
Plan B's Avatar
Default Re: (nigel)
475 is what i heard. cruddy dyno however.
Old Sep 22, 2003 | 01:28 PM
  #50
GreddySi99's Avatar
Default Re: (Plan B)
also the boost is not turned up. I am sure his setup is much more capable than the 475 he laid down. that was just a tease as the thread clearly states
