tdo5
Old Oct 8, 2005 | 11:10 PM
90crxsi88zc's Avatar
Default tdo5
i have a few probs.. like two.. ok i have a vortech 10.1 fmu.. will that and rotating the distributer .5 degrees let me safely run 6lbs on my zc? and next.. do i need coolant running through the turbo? some say no some say yes.. please help! thanks
Old Oct 9, 2005 | 12:02 AM
CRXDrew's Avatar
I'm not a big fan of FMU's... esspecially with the abundance of resources for TurboEdt/other free ems's. .5 of retard won't do much... you should be fine staying stock. 6lbs ain't much.
I would run coolant. Keep the turbo happier. I have a tdo5h 14b and yea... it was cheap... everyone was like.. its a cheap turbo.. why bother running the lines. I figure why not.. a couple feet of hose and ur done. Also I don't even worry about turbo timing because of the coolant.
Old Oct 9, 2005 | 02:10 AM
blackccoupe's Avatar
Default Re: tdo5 (90crxsi88zc)
ran no coolant lines in my z6 not the same motor but similiar ran great til my ringlands went bad
Old Oct 9, 2005 | 02:28 AM
Default Re: tdo5 (blackccoupe)
oh yeah ran a fmu lol
Old Oct 10, 2005 | 02:14 PM
Default Re: (CRXDrew)
ok cool.. and thanks.. where do i run coolant from? the throttle body and back?
Old Oct 10, 2005 | 02:16 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: (90crxsi88zc)
does your turbo have provisions for both oil and water cooling?
Old Oct 10, 2005 | 02:17 PM
whats a ringland? my turbo was just rebuilt.. do you think i should run it?
Old Oct 10, 2005 | 02:33 PM
wantboost's Avatar
Who is Mr Robot?
did you listen to anything i just said.... does your turbo ahve provisions for running both oil and water cooling... heres a simple way to tell.... how many holes are on the middle of your turbo?? (even youcan get this one.... i think)
Old Oct 11, 2005 | 01:08 AM
Default Re: tdo5 (wantboost)
many people have not run the coolant lines and have no problems in my opinion just a pain in the *** lol, do a search u will find many results bout this!
Old Oct 11, 2005 | 03:59 AM
Bartman201's Avatar
if it has the water inlet used it. longer turbo life
Old Oct 11, 2005 | 09:36 PM
yeah it has a coolant inlet and an outlet.. i could take it from the throttle body because in new orleans its pretty funing hot.. but anyway.. i thik its too much of a bitch to run but i mean hey if i need it ill do it.. if not then i wouldnt worry about it..
A2gt35r
May 5, 2007 06:04 PM
1QwIkEf
Jan 29, 2006 07:47 PM
You_Get_Vapors
May 4, 2003 06:17 PM
