td05hr twin scroll
Old Sep 25, 2008 | 07:00 PM
koulaid's Avatar
Default td05hr twin scroll
Just picked up a td05hr 16g (little to no shaft play) for $150. good price? well the thing is. Can i just use a standard log manifold and fab up an adapter plate to it? Does it matter how the manifold is fabricated because the turbo is twin scroll or can a regular manifold be fine? thx
Old Sep 26, 2008 | 10:03 AM
thatblkguy's Avatar
i paid 100 bucks for mine
which one did you get? and no you cant just us a log manifold. the manifold has to be a twin scroll!! for it to work the turbo has to work as if it was on a evo to work like it should.
Im working on the same set up
Old Sep 26, 2008 | 10:50 AM
RubenPrelude's Avatar
You can use a normal(undivided)manifold. But then you won't have the advantage of divided.
Thatblkguy:please explain me, why you have to use a divided manifold, and why you can't use a normal mani..
Old Sep 26, 2008 | 11:03 AM
HiProfile's Avatar
Default Re: (thatblkguy)
It doesn't HAVE to be divided, but you'll benifit greatly in terms of power and spool time with a divided manifold.
Old Sep 26, 2008 | 11:19 AM
thatblkguy's Avatar
hipro u beat me to it
While it does not cause any problems to run a divided inlet turbine housing on a manifold that is of open design, but none of the real benefits (quick spool) of the twin scroll set up will be seen.
so then thare would be no point in using it.
Old Sep 26, 2008 | 11:44 AM
LastGenEK's Avatar
Why would you buy twin scroll and use a log???
You can find a divided mani and it would be a fun turbo++
TheShodan's Avatar
Moderator
For that size turbocharger for his application, his "quick spool" won't be an issue.
Please remember that in order to be "twin scroll", you have to use a divided turbine housing, but simply a divided turbine housing does not make it "twin scroll"
Old Sep 26, 2008 | 04:17 PM
koulaid's Avatar
Default Re: (TheShodan)
sorry to be a noob and all at this TWIN SCROLL stuff. i got the turbo for cheap so i took it. i just havent seen a manifold that was TWIN SCROLL or divided inlet that i can buy. someone direct me to it? ive searched a ton on here, turbod16, and d-series.org. would i have to custom make one?
Old Sep 26, 2008 | 04:48 PM
koulaid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thatblkguy &raquo;</TD></TR><TR><TD CLASS="quote">i paid 100 bucks for mine
Im working on the same set up</TD></TR></TABLE>
i have the td05hr 16g 9.8t
did you have a custom made manifold?
Old Sep 26, 2008 | 07:58 PM
TheShodan's Avatar
Moderator
You're going to need to have one made, and find the Evo flange to use to fit both that turbo and the bolt pattern to the head.
Old Sep 27, 2008 | 07:56 AM
HiProfile's Avatar
As mentioned, you'll need one made specificly. THose turbos aren't normally put on Hondas, and is an 'unusual' divided inlet. The vast majority are divided vertically (down the short center), and yours should be down the diagonal. THe collectors aren't as easy to make for the average honda fabricator.
The turbo on a normal manifold will spoll faster than a 50trim t3/t04e for reference, and will get you past 300whp w/o much of an issue.
Old Sep 29, 2008 | 09:43 AM
thatblkguy's Avatar
Default Re: (koulaid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by koulaid &raquo;</TD></TR><TR><TD CLASS="quote">
did you have a custom made manifold?</TD></TR></TABLE>
Im using a XSpower evo 8 manifold moded to fit my ls. got it really cheap
Look on the evo forums for deals on the parts your going to need like tthe manifold
Old Oct 20, 2008 | 04:47 PM
mantella's Avatar
I know this is a old post to reply to but I did the same thing as another user posted with using a xspower manifold. On my d series it takes more work to pull off since the ports are closer together. you would still have to by a d series exhuast flange and some piping to make it work. A person on homemade turbo just had one custom made and dynoed it. they can put out some rather impressive numbers and spool very fast.
Old Oct 20, 2008 | 09:54 PM
HiProfile's Avatar
Default Re: (mantella)
Would you care to link to the HMT thread? I really can't find it, and not for a lack of looking. Am I to assume the XS mani was basicly a NA header converted to a topmount style, and kept divided?
Old Oct 21, 2008 | 08:17 AM
thatblkguy's Avatar
I just cut off the evo flange and welded the blox flange on the evo manifold. Im still not done Need a front mount and piping.
http://www.homemadeturbo.com/f...232.0
Karsten
Jul 19, 2018 12:06 PM
eg2phosizzle
Welding / Fabrication
11
Jan 24, 2006 09:37 AM
Ybnorml
Sep 22, 2003 06:49 AM
TurBoXBirD16
May 7, 2003 01:20 PM
