Tapping oil return
Has anyone tapped their oil return on an H22 Aluminum oil pan. I was surprised to see my stock pan is aluminum. Was going to buy a moroso pan but with my ATTS it doesn't look like I have room. Any leak problems with tapping the pans or is it better to have a bung welded on?
mine's not an H22, but it is aluminum. I would definitely weld a bung into aluminum. the pan wall isnt that thick, and aluminum is soft enough you may pull the threads out.
Welding is leak proof.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rob97’SH »</TD></TR><TR><TD CLASS="quote">Has anyone tapped their oil return on an H22 Aluminum oil pan. I was surprised to see my stock pan is aluminum. Was going to buy a moroso pan but with my ATTS it doesn't look like I have room. Any leak problems with tapping the pans or is it better to have a bung welded on?</TD></TR></TABLE>
We always weld a bung on, this way if you ever take the turbo off you just plug it up.
