Tapping manifold for external gate question. Placement of hole?
Old Feb 26, 2003 | 03:12 PM
mechanik's Avatar
Default Tapping manifold for external gate question. Placement of hole?
Hi. I have a manifold just like the one pictured here
On the picture they have the wategate mounted on the second runner (from the left).
On Drag Manifolds and Revhard, the wastegate is placed more to the right, near the 3rd and 4th runners. My buddy is going to take it to work and have his guys cut it and weld on my flange. Should I have it welded on spot 1 or 2? BTW, my turbo will be mounted with the compressor on the passenger side.
Old Feb 26, 2003 | 03:19 PM
turbopimp's Avatar
Default Re: Tapping manifold for external gate question. Placement of hole? (mechanik)
Ummm.... Location "1 and a half" would be best... that is to say, the wastegate port should be at the collector or turbine inlet flange for best boost control. Just make sure the wastegate will clear any ac lines, fan shrouds, etc. before welding the wastegate flange on...
Old Feb 26, 2003 | 03:25 PM
mechanik's Avatar
Default Re: Tapping manifold for external gate question. Placement of hole? (turbopimp)
So right in the center would be the best spot? Anyone else have input? I know the Drag and Revhard manifolds aren't as "loggy" as mine, but they put theirs toward the 3rd and 4th runners...
Old Feb 26, 2003 | 03:45 PM
mechanik's Avatar
OOps, fixed last picture.
Old Feb 26, 2003 | 03:57 PM
DeepSi's Avatar
the center is the best spot like on the inline pro manifold.
Old Feb 26, 2003 | 06:03 PM
SJP0tato's Avatar
Default Re: Tapping manifold for external gate question. Placement of hole? (DeepSi)
If you can, borrow or purchase a copy of "Maximum Boost" by Corky Bell. He explains wastegate placement, along with almost every other detail about turbocharging in nice detail. I agree with everyone else, space permitting in the middle above the collector would be best.
Good luck,
Ryan P.
stocker2shocker91
Oct 26, 2006 10:45 PM
Acura_I-RS
Apr 18, 2005 09:23 AM
platinum00
Sep 22, 2003 10:39 AM
2.2
Sep 17, 2002 07:13 AM
boosted3g
Dec 7, 2001 02:17 PM
