T1R and JRSC?
Old Nov 18, 2003 | 09:08 AM
skygtr01's Avatar
Default T1R and JRSC?
Has anyone tried the T1R Response header with a JRSC? Any gains or weaknesses? I want to upgrade from my 2.25 Comptech to a 2.5, but stay with a quality product. Thanks.
Old Nov 18, 2003 | 09:30 AM
Rory Breaker's Avatar
Default Re: T1R and JRSC? (skygtr01)
I had great results with my Kami/Carsound 2.5" setup. Any pictures of the T1R header? The charger likes short primaries.
My header/cat is FS BTW
Old Nov 24, 2003 | 08:47 AM
skygtr01's Avatar
Default Re: T1R and JRSC? (newgsrdriver)
These were the only pictures I could find, kind or hard to tell from an angle. What do you think?
Old Nov 24, 2003 | 07:52 PM
skygtr01's Avatar
Nobodys used this set up?
Old Nov 24, 2003 | 07:55 PM
falcongsr's Avatar
What is this crap?
i am unfamiliar with that header but its basically the complete opposite of a kamikaze header which has much shorter primaries. i dont know if thats good or not...
Old Nov 24, 2003 | 09:01 PM
tegasaurus's Avatar
Default Re: (falconGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by falconGSR &raquo;</TD></TR><TR><TD CLASS="quote">i am unfamiliar with that header but its basically the complete opposite of a kamikaze header which has much shorter primaries. i dont know if thats good or not...</TD></TR></TABLE>
longer the primaries, the worse power you'll see. You want those primaries to dump straight into a collector about 10-15" away (about 2.5").
goodluck with ur setup
Old Nov 24, 2003 | 09:09 PM
Blue-Civic-Hybrid's Avatar
Loved
I love my Kamikaze 2.5 setup with 2.5 high flow cat and 2.5 piping thruout my exhaust..works great and proven power. But i just recommend that you torque the crap out of the Kami header where it meets up with the B-pipe, they are notorious for leaking there...
Old Nov 25, 2003 | 08:55 AM
skygtr01's Avatar
Default Re: T1R and JRSC? (Blue-Civic-Hybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blue-Civic-Hybrid &raquo;</TD></TR><TR><TD CLASS="quote">But i just recommend that you torque the crap out of the Kami header where it meets up with the B-pipe, they are notorious for leaking there... </TD></TR></TABLE>
I guess I'll go with the Kami, but I am a little worried about the quality.
Old Nov 25, 2003 | 09:11 AM
Yep, primaries seem way too long.
Dont worry about the Kami quality...theyve taken steps to solve some problems. Supposedly using better hardware for one, and copper gasket for another. I never had any problems with mine blowing out.
Id clean it up a bit, maybe have a machine shop do some quick work on the ports and go to town.
Old Nov 25, 2003 | 10:16 AM
patdemps's Avatar
Go with the Kamikaze if you want good numbers and results. As stated above, do what you can during the install to prevent any leaks. I'd PM Nick (newgsrdriver) and take his off his hands, if I were you.
Old Nov 25, 2003 | 03:58 PM
Stock@$$GSR's Avatar
Default Re: (tegasaurus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegasaurus &raquo;</TD></TR><TR><TD CLASS="quote">
longer the primaries, the worse power you'll see. You want those primaries to dump straight into a collector about 10-15" away (about 2.5").</TD></TR></TABLE>
Does anyone know why you want short primaries? also, why 2.5" instead of 3" diameter? I thought all FI wants the least restriction possible for more flow? I'm not challenging or disagreeing with you, just trying to get my learn on
Old Nov 25, 2003 | 05:47 PM
tegasaurus's Avatar
Default Re: (Stock@$$GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stock@$$GSR &raquo;</TD></TR><TR><TD CLASS="quote">
Does anyone know why you want short primaries? also, why 2.5" instead of 3" diameter? I thought all FI wants the least restriction possible for more flow? I'm not challenging or disagreeing with you, just trying to get my learn on </TD></TR></TABLE>
reason i said 2.5" collector is because, as limited as my n/a mod (header) knowledge is, there is no 3" collector made on any header.
Old Nov 25, 2003 | 06:20 PM
ATgrills.com's Avatar
Im still using my JDM DC 2.5 inch collector,,,
but i can trade for a kamakazi for an even trade if I want!
Is it worth it?
Tyler
Old Nov 25, 2003 | 07:17 PM
morepoop4u's Avatar
reason i said 2.5" collector is because, as limited as my n/a mod (header) knowledge is, there is no 3" collector made on any header.</TD></TR></TABLE>
if you want a 3 in collector you can just weld a 3 in flare to it. here's what i did;
i would have had 230whp but the manifold was getting hot
this is at 6 psi and hondata + bolt ons
ITR-965
Jul 3, 2006 06:23 PM
TrizzyDizzy
14
Feb 5, 2005 03:41 PM
HYREV2NR
Dec 28, 2003 09:59 PM
2000R
Jul 10, 2002 05:15 PM
