T04E rpm boost range
Old Jan 8, 2006 | 05:53 PM
idewson's Avatar
Default T04E rpm boost range
Can you estimate boost rpm range as well as what rpms i should make good power to. Setup: T04E 57 trim, .60 A/R Compressor, .63 Turbine, log manifold, 2.5" ic piping
Are we talking starting boost mid 2k-3 up to 5.5-6k? or is it starting higher like 3.5-4k up to 7k?
All input is appreciated!
Old Jan 8, 2006 | 05:54 PM
Schister66's Avatar
Man U FTW
what engine and what compression??
Old Jan 8, 2006 | 06:47 PM
idewson's Avatar
Default Re: (Schister66)
My bad...it F22 with 8.8 compression
Old Jan 9, 2006 | 07:16 PM
yee SERIOUS's Avatar
are you talking about a straight t4? or a t3/to4e hybrid?
IM'd you bigdaddyvtec
Old Jan 10, 2006 | 11:22 AM
idewson's Avatar
Default Re: (bigdaddyvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigdaddyvtec &raquo;</TD></TR><TR><TD CLASS="quote">I believe the 63 gets boost at 5k, too high for the f22s rev ceiling (IMHO). </TD></TR></TABLE>
That was my concern. I figured with the log manifold i could get a quicker spool. I was hoping to be able to make power to 7k after valve work, cam, pistons, rods, lightened/balanced crank etc...Is that even possible? What will porting the head or swaping the head get me? I've heard of getting to 7k but from what i hear that doesn't mean power is being made to 7k. What do you think is the best solution...getting the .48hot/.50cold instead of .58hot/.63cold or trying to make power in higher rpms?
Now...one of the main reasons for not being able to make power @ higher revs is because of the 8.8 compression right? Could i get custom pistons with something like 10:1 or something to be able to make power higher?
Old Jan 10, 2006 | 12:26 PM
idewson's Avatar
Thanks for the info...a big help!
Are you still talking about stock internals? And what did you tune with?
Old Jan 10, 2006 | 12:48 PM
idewson's Avatar
I'm planning to boost in the spring and going with the 48/50 sounds like a plan. I will be swapping in the H22 manual trans in place of my auto so that should give me some extra tq and get me movin faster. I think getting around 270 whp if i can will be plenty for now and then improve internals later for higher boost and power.
Just curious...what kind of power do you think you could get running on 20-25 psi? Are we talking 325-350 or more?
What clutch are you using?
blackpearlcivic
Jan 26, 2006 05:24 PM
ying_YANGtwin
Dec 16, 2004 05:55 PM
christof
Jun 3, 2004 07:22 AM
Mr.DC2TurBo
Feb 12, 2004 06:43 PM
