swapping compressor wheels
Old Oct 14, 2002 | 10:58 PM
ludelvr's Avatar
Default swapping compressor wheels
just wanted to know what would be involved in swapping out my compressor wheel for something a bit bigger. I currently have t3 from a merkur and it has a .60 ar. I want something that will flow a bit more so I was wondering if it was possilbe to swap in a compressor wheel from a t4 or something. If I did this, would I be able to retain the same housing or would I have to change that too? I read about altering the turbo, but I was unclear about changing just the compressor wheel. Any help would be awsome!
Old Oct 14, 2002 | 11:17 PM
Flamenco-T's Avatar
Default Re: swapping compressor wheels (ludelvr)
if the housing trim is the same, yes you can, but I would get it rebalanced anytime you change out the wheel.
just call innovative, majestic or turbonetics and see what they suggest.
Old Oct 15, 2002 | 08:59 AM
Sonny's Avatar
The .60 a/r on the compressor housing does not tell you any info about what compressor wheel is inside the turbo. I believe that the Merkur T3 has a 60 trim wheel. The only other T3 wheel available to you is the Super 60 and for all of the work required, it isn't worth it (IMO).
If you want to switch to a T4 compressor, you need a T4 compressor wheel, a T4 compressor housing, and a new backplate.
Sonny
Old Oct 16, 2002 | 01:55 PM
ludelvr's Avatar
Default Re: swapping compressor wheels (Sonny)
what work would be involved? And how much difference is there with the super 60?
Sonny
scartail
Dec 19, 2004 04:54 AM
Ri5e
Sep 9, 2004 03:52 PM
Wideopentuning
Jul 15, 2004 07:44 PM
Stock@$$GSR
Apr 18, 2002 06:22 AM
