Surging Idle after JRSC
Old Sep 23, 2004 | 08:57 PM
Weapon_R's Avatar
Default Surging Idle after JRSC
I've seen a few guys have this same problem. After I installed the JRSC on my Integra LS, the RPMS keep surging from 1000-2000 nonstop.
Is there any idea on how to fix this? Seems common enough that someone must have a fix. I've checked for vacuum leaks everywhere.
Old Sep 23, 2004 | 09:02 PM
keebler65's Avatar
Default Re: Surging Idle after JRSC (MickeyA)
probably a vacuum leak. check all of the seals (between blower and manifold, and s-pipe and throttle body). also check all of the vacuum lines.
Old Sep 23, 2004 | 11:50 PM
FOrSfEd's Avatar
Default Re: Surging Idle after JRSC (keebler65)
Yeah I would say 99% it is a vac leak
Old Sep 27, 2004 | 04:16 PM
prestonpark's Avatar
Default Re: Surging Idle after JRSC (FOrSfEd)
u miight wanna titen the blower to the manfold hard that wat cause mines and replace the iacv gasket or o ring mine surges to
get some carberater cleaner and spray it at where the iac meat the s tube
spray alot
Old Sep 27, 2004 | 04:19 PM
https://honda-tech.com/zerothread?id=971806
spray this thing on top c does it werk
Old Sep 27, 2004 | 08:13 PM
Weapon_R's Avatar
Default Re: Surging Idle after JRSC (civic2003)
Can you be more specific? What is the S-Tube?
Old Sep 27, 2004 | 08:48 PM
just spray carb cleaner on the pik i show u it a link
Old Sep 27, 2004 | 08:49 PM
spray where ir iacv is
MOVE OVER
Jul 31, 2009 03:34 PM
mike3
Sep 9, 2007 05:44 AM
Ls5000
Dec 16, 2005 12:20 PM
Weapon_R
Sep 12, 2004 02:37 PM
jbs
Mar 14, 2004 05:14 PM
