supertech valve kit and cams
Old Mar 3, 2010 | 03:55 AM
crashsvg's Avatar
Default supertech valve kit and cams
hey guys ..am rebuilding my b18c head with a supertech valve kit (standard size valves) stock port also..am looking to run between 500-600whp..my bottom end is already rebuilt and am using a precision 6262
am wondering if my stock cams could do the trick?if not what cams would be compatible do the trick?
Old Mar 3, 2010 | 01:21 PM
DA TeG 90's Avatar
Default Re: supertech valve kit and cams
skunk2 tuner2 cams, skunk2 pro 1 or bloxB cams.
Old Mar 3, 2010 | 01:51 PM
E85B18's Avatar
GSR cams can get you 500-600, but you will get there running less boost with the cams TeG90 recommended
Muckman
Apr 7, 2012 06:56 AM
ProjectJDM
Feb 23, 2010 10:49 AM
hrtagrm
Honda S2000
Oct 11, 2008 05:19 AM
The Si
Feb 22, 2007 03:17 PM
yellowmonkeyboy
Feb 16, 2005 11:04 AM
