supercharging a b16?
hey i wanted to know about how much power a high boost jrsc with hondata s300 with an 11psi pulley on a jdm b16 with a hacked air box, apexi world sport 2 cat back and a magnaflow high flow cat. also if i put the super charger on would i be able to safely go up to 11 psi without upgrading any internals or what would be the safest and highest to go to? anybody have a similar setup? how is it? was it worth it?
11 psi's is unsafe with a stock JRSC due to heat issues at that psi. if you get the LHT intercooler mod then you can boost close to 12 psi safely but anything higher then that is pushing the limits of the blower. check out the huuuge JRSC thread, that will answer most your questions but your looking at anywhere between 240-300HP tops with a modded JRSC. now add some nitrous to the equation and thats a different story.
11psi, 300, b16, b16b, honda, hp, injection, jdm, kit, meth, supercharg, supercharged, supercharger, superchargin, supercharging
