supercharger BOV???
Old Dec 29, 2002 | 12:07 PM
sslude's Avatar
Default supercharger BOV???
do you supercharders use BOV's? i was riding in a civicSI with a vortech SC and when he let off the throttle it sound like a quiet BOV. if they do, what are they used for? do they use watsegates?
Old Dec 29, 2002 | 12:08 PM
Daniel's Avatar
Default Re: supercharger BOV??? (sslude)
vortechs use a BOV. . . .
Old Dec 29, 2002 | 03:44 PM
rjardy's Avatar
Yes a supercharged vehicle can utilize a BOV, no superchargers dont use wastegates, the PSI is set via pulleys, the pulley only lets the SC spin fast enough to creat the desired amount of presure that the pulley was designed to generate.
Rob
Old Dec 29, 2002 | 05:09 PM
Rory Breaker's Avatar
Default Re: supercharger BOV??? (rjardy)
Its more of an exhale than a blowoff
Old Dec 29, 2002 | 07:20 PM
double0Si's Avatar
Default Re: supercharger BOV??? (newgsrdriver)
We supercharged, usually refer to them as by-pass valves. but it is the same as a BOV. If it was quiet it was probably recirculated back into the intake tube. If I vent mine to the atmosphere it is very noticable.
At steady speeds they will make a constant pshhhhh noise, like on the highway, because the sc is always blowing air.
Old Jan 5, 2003 | 01:51 AM
ED8DX's Avatar
Default Re: supercharger BOV??? (double0Si)
The by pass valve will tend to bleed off excess continually, rather than blow out the pressure all at once.
Hand_Fed
Apr 22, 2010 04:51 PM
94greddycivic
Apr 23, 2005 05:33 AM
whitetyper
Oct 11, 2003 08:54 PM
ILOVEGIRLS
Jun 27, 2002 05:41 PM
