supercharged ls vtec help
Old Aug 13, 2009 | 10:01 PM
GSR615's Avatar
Default supercharged ls vtec help
i was thinking about supercharging my ls vtec that is built for all motor ..
its built with with a gsr head. the head has some super tech valve spring and retainers , crower stage 2 cams and a port and polish. and also has high comp. valves.
then the bottom has some p30's with stock rods with arp rods bolts. also has the gsr main caps girdle and ARP head studs and main studs.
i did balanced rotating assembly including flywheel and clutch.
would this set up work with the supercharger.
is there any advantage with my motor being high comp. with the supercharger
if anybody could put me in the right direction thanks for the help..
Old Aug 13, 2009 | 11:48 PM
wunfstgsr's Avatar
Loved
Community Favorite
Default Re: supercharged ls vtec help
heres my set up!!
https://honda-tech.com/forums/appearance-build-threads-122/c-street-sleeper-want-feedback-comments-lots-pics-%2A%2A%2A-2556604/
Old Aug 14, 2009 | 11:39 AM
I CRX I's Avatar
^-----read his build, should teach you alot about the direction your going in.
Old Aug 16, 2009 | 05:47 AM
crashsvg's Avatar
what type of supercharger are you looking to use?high compression of about 11.0:1 is good for 9-12lbs of boost depending the cfm of the charger.after that it gets a lil tricky when tuning..
Old Aug 17, 2009 | 10:08 PM
GSR615's Avatar
probably a jrsc..
i know i want aleast 250whp or more if possible
TealCivic115
Nov 8, 2010 08:08 PM
UndisputedH22a
20
Jun 21, 2010 05:31 PM
stratedrm
28
May 21, 2009 07:38 PM
DA9tegra
Aug 14, 2008 07:45 AM
